Knock sensor needed?
Old Jan 18, 2005 | 08:45 AM
Running925's Avatar
Default Knock sensor needed?
Hey guys, i'm somewhat new to the forums over here at Honda-Tech, i'm usually over at honda-acura.net.. but anyways. I've been into the import scene pretty heavily for the last 2-3 years. I've got a question about my swap. I've done some research about a possibly needed knock sensor & i'm not sure if this is needed for my swap or not.
I'm working with a 95civic ex body & i've got a built b18a1 sitting here that i'm ready to drop in, i'm just tryin to work out all the details before i put it in & realize that i've forgotten something. I've set it up for boost & i need to know if there is actually a need for a knock sensor or not. I've read that people are taking out the 3rd altornator bracket bolt & inserting one there when they do it but i just can't seem to to find hard facts as to weather or not i actually need to do this with my appliation. Any & all information about this would be greatly appreciated. Thanks in advance.
Tony
:edit.. almost forgot.. i've changed everything to obd1
Old Jan 18, 2005 | 08:58 AM
handa's Avatar
Default Re: Knock sensor needed? (Running925)
which ECU are you using?
Old Jan 18, 2005 | 09:00 AM
Running925's Avatar
Default Re: Knock sensor needed? (handa)
obd1 ecu from a 94-95 integra
Old Jan 18, 2005 | 09:05 AM
ian.'s Avatar
b18a1's don't have knock sensors so your not gonna have to have one depending on your ecu like if you have a p28 its obd1 with no knock sensor
Old Jan 18, 2005 | 09:16 AM
handa's Avatar
Default Re: Knock sensor needed? (IC33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IC33 &raquo;</TD></TR><TR><TD CLASS="quote">b18a1's don't have knock sensors so your not gonna have to have one depending on your ecu like if you have a p28 its obd1 with no knock sensor</TD></TR></TABLE>
HiMason
Jun 28, 2014 02:53 PM
prelude182
Jan 14, 2010 09:42 PM
aasaa666
Engine Management and Tuning
May 14, 2009 06:43 AM
LSEGHATCH
Apr 5, 2005 03:07 PM
delslow94
Dec 26, 2002 12:52 PM
