Dc integra brakes on my 89 crx si?
Old Jan 18, 2005 | 08:14 AM
mekanism's Avatar
Default Dc integra brakes on my 89 crx si?
Will the rear brakes from a 94 integra LS fit on my ef? I have the whole integra for parts. I was hoping I could just swap the hubs out for the ef hubs and then bolt the disc brakes to that. Anyway, I just wanted some advice before I go tearing into this!
Old Jan 18, 2005 | 08:34 AM
EL Vap133's Avatar
Default Re: Dc integra brakes on my 89 crx si? (mekanism)
Yes! Just use your stock struts/shocks, LCAs, and compensator arms for the rear. You're also gonna need 90-91 crx si e-brake cables. Check this link out for more help: https://honda-tech.com/zerothread?id=930462
Old Jan 18, 2005 | 08:53 PM
fastassdx's Avatar
From: Come back next year and Ill put some, eggnog in your face, US
Default Re: Dc integra brakes on my 89 crx si? (EL Vap133)
I did that swap myself on my 88 EF9, as for the parkingbrake cables you can use them off of a DA fo sure; I did.
Old Jan 19, 2005 | 05:43 PM
mekanism's Avatar
Default Re: Dc integra brakes on my 89 crx si? (fastassdx)
Well, when I went to look at the trailing arm to see what would work, I noticed it had been damaged in the crash. When the car was rolled it tucked the wheel under the car a little causing the hub to rip some of the sheet metal from the trailing arm. So it looks like I wont be able to use it. Would it be possible to use the just the hub? Will the torx bolt holes line up? If not then it looks like I will have to go to the yard to get more parts.
gearhead16
Feb 23, 2009 05:38 PM
98integralsB18
11
Sep 4, 2008 07:52 PM
wunPOINTeight
Jan 15, 2007 02:26 PM
BOSS-REX
15
Oct 2, 2004 03:56 PM
AfEn808
Oct 31, 2001 09:17 AM
