Slave clutch cylinder
Old Jan 18, 2005 | 08:11 AM
mavshah's Avatar
Default Slave clutch cylinder
I found that I have a leak somewhere in the slave cylinder. I bleive its a simple job to change this, but anythign I need to make sure before I change it. any help is appreciated
Old Jan 18, 2005 | 09:08 AM
JimBlake's Avatar
Default Re: Slave clutch cylinder (mavshah)
Replacing the slave cylinder is simple. Then you have to bleed the clutch, so search around for that procedure. Ever bleed your brakes? If so, you should be able to bleed the clutch.
Old Jan 18, 2005 | 12:09 PM
syclone's Avatar
Default Re: Slave clutch cylinder (JimBlake)
bleeding clutch is a different method from bleeding brakes..
Old Jan 18, 2005 | 12:59 PM
JimBlake's Avatar
Default Re: Slave clutch cylinder (syclone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by syclone &raquo;</TD></TR><TR><TD CLASS="quote">bleeding clutch is a different method from bleeding brakes..</TD></TR></TABLE>Yes, so find the procedure. What I meant was if you know how to bleed brakes, you'll find that bleeding the clutch is not really more difficult.
Old Jan 18, 2005 | 02:57 PM
mavshah's Avatar
ok got it.. yeah i have read the procedure for bleeding the clutch.. so will get that.. thanx guys...
PaulMc
May 18, 2014 05:04 PM
alx_90ef
Jun 14, 2009 01:30 PM
vtakvtrak
20
Dec 13, 2005 04:03 PM
nubs
Dec 16, 2004 03:28 AM
DriveSideWays
Aug 27, 2004 05:06 PM
