..... Thermostat. How Do You Change Em?......
Old Jan 17, 2005 | 11:58 PM
W O T's Avatar
Default ..... Thermostat. How Do You Change Em?......
I feel retarded for even asking this question. Ive done everything from tranny swaps to shifter installs and even a turbo setup but I have never thought about or attempted to replace my thermostat..
Well being in Canada it gets cold as ****, and for the last 2 months my cars been taking a long time to worm up, I thought it would just be because it was cold out, but today I tried to use my heater and it didnt start blowing hot air, tried again after work after a 10 min warm up and still nothing (only 2 miles home)
So Im thinking my thermo is sticking open or whatever.
The car is a 88 Crx and I dont even know where the thermostat sits. Also what kind do I have to buy for winter driving, wanting the car to heat up and blow hot air as quickly as possible.
Like are they just labelled as Honda thermos or are they all the same?
Anyone have any pics or little guides I can peek at
I plan on running no thermo in the summer when I drop in the built motor and turbo but I need some warmth in this Canadian bullshit
Thanks
Old Jan 18, 2005 | 12:07 AM
JDMH22HATCH's Avatar
Default Re: ..... Thermostat. How Do You Change Em?...... (W O T)
Follow you lower radiator hose up to where it meets the motor. That is the thermostat housing. There will be 2 10mm bolts you will have to undo and then pull off the housing. Then pull out the thermostat replace it with the new one, and put the housing back on and put the 2 10mm bolts back in. Wallah
Old Jan 18, 2005 | 12:57 AM
Luserkid's Avatar
Default Re: ..... Thermostat. How Do You Change Em?...... (JDMH22HATCH)
Edit: Scratch that its the lower.
Old Jan 18, 2005 | 01:05 AM
W O T's Avatar
Default Re: ..... Thermostat. How Do You Change Em?...... (Luserkid)
****, didnt think it was that easy to change em. Ive changed them on a 350 before, sounds the same. Theres a ground wire to right?
Now about buying one, anything special for Hondas?
I guess Im looking for one with a higer temp, like itll say 185* on the package right? no special mumbo jumbo language
Old Jan 18, 2005 | 02:05 AM
komat's Avatar
search is your friend...
https://honda-tech.com/zerothread?id=876298
Old Jan 18, 2005 | 02:59 AM
JDMlyfestyle's Avatar
finally my thread becomes useful
Old Jan 18, 2005 | 03:32 AM
eL's Avatar
eL
My car takes a long while to warm up as well.. a bad thermostat causes this?
Old Jan 18, 2005 | 04:35 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: (eL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eL &raquo;</TD></TR><TR><TD CLASS="quote">My car takes a long while to warm up as well.. a bad thermostat causes this?</TD></TR></TABLE>
yep. it could be stuck open.
Old Jan 18, 2005 | 06:16 AM
mike1114's Avatar
Default Re: (AzntaggeR)
take an air hammer to it!!!!! just kidding
Old Jan 18, 2005 | 07:11 AM
alotawatts's Avatar
When you're done be sure the ground wire connection at the t-stat is clean and tight.
Old Jan 18, 2005 | 08:01 AM
JimmyAtlantis's Avatar
I wonder if that's why my fan never kicks on and my idle sucks. It never gets warm enough for the fan and my idle stays a little high even after adjustment. How much coolant needs to be replaced?
Old Jan 18, 2005 | 08:03 AM
Coolant level has to be completely full.. u will know this when the coolant spills out of the radiator. then start the car and allow it to warm up and add coolant as it goes along this will help bleed the cooling system with air
Old Jan 18, 2005 | 10:06 AM
W O T's Avatar
Default Re: (JDMlyfestyle)
I honestly searched and didnt find that thread there man
Ok so the thermo is easy, now what about coolant drainage and complete refill
Might as well for a few more bucks
Turn the car off, let it cool down for an hour, and theres a drain valve at the bottom correct? or can I just pop off a hose? drain out all the coolant
put the plug back in
insert 3-4L of 50/50 coolant/water until it overflows?
Turn the car on with the rad cap off until the water starts to bubble or what?
Thanks guys
Old Jan 18, 2005 | 10:29 AM
yup just follow my write up and ull be all good.. yes there is a drain plug. dont pull off the hose unless u want coolant everywhere..lol
Old Jan 18, 2005 | 10:34 AM
Chillin94hatch's Avatar
2 questions...
1) Blowing out "Warm" air....not as hot as it used to be, could it be the thermostat?
2) Are all D-series thermostats the same?
Old Jan 18, 2005 | 11:12 AM
could be the thermostat sticking a little bit. could be some wear on your heater core.
could have a air bubble in the system
Old Jan 18, 2005 | 03:17 PM
komat's Avatar
Default Re: (W O T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by W O T &raquo;</TD></TR><TR><TD CLASS="quote">I honestly searched and didnt find that thread there man
you have to look in the Archived content too when searching most of the good DIY are in the Archived content.
732xghost
Aug 26, 2009 07:20 AM
732xghost
Aug 23, 2009 08:48 PM
vic_houston
Jan 3, 2008 08:59 PM
Thunder Cat
Feb 10, 2007 03:09 PM
Hondaciv95VX
20
Dec 5, 2005 01:41 PM
