Help! CAR Doesn't start, CHECKED EVERYTHING!
I put a new starter, new battery, new distributor, but nothing. Turn the key no sound, besides the relay switching over.
Tested the starter wire to see if its gets voltage when the key turns over but nothing! So i'm guessing it's the ignition.
I check the ignition and no power to the Black/White & yellow wire, in the III position.
What the heck? :
I checked all my fuses, nothing blown. It just starting to happen
This is an 89 Civic DX. AND YES I DID A SEARCH!
What the heck? :
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IronOutlawz »</TD></TR><TR><TD CLASS="quote">if it is the clutch switch take it off and put a wire going to both of the terminals on the plug and see if it starts.</TD></TR></TABLE>
Im gonna go check that, i hope this works!!!!
thanks for the quick reply guys, i'll let you guys know if it works.!!!
1) I cut the two wires (Blue & Black) leading to the clutch pedal switch and connected them two. So now i don't have to deal with that problem
2) I add another tranny ground to the chasis.
3) i changed the 'Main" rely (I think it is located on the diver side kick panel, has like 7 pronges on it).
4) check my ECU light, it only flashed once, and it was off.
results
Still the same things. When I turn the key to position III, it doesn't do anything, besides the relay (located behinds the center console) clicking. nothings else!
ARGHH pain in the ***.
I know i'm getting power, doubled check the leads from the ignition switch and still no power coming from the yellow wire and the black/white. SAD
results
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IronOutlawz »</TD></TR><TR><TD CLASS="quote">ive done all that and even replaced my ignition switch and it still doesnt work. im sure Tuan is feeling the same way i am.</TD></TR></TABLE>
Did you ever fix your problem? I'm still stumped.
Gonna wait for a new ignition switch... and see what happens after
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tuan »</TD></TR><TR><TD CLASS="quote">
Did you check before or after ?
nope still havent fixed the problem. im sick of screwin with it so im gonna wire a push button on it. but in the mean time if anyone has fixed a problem like this i sure would like to know.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx »</TD></TR><TR><TD CLASS="quote">
Did you check before or after ?</TD></TR></TABLE>
What do you mean before or after? I check while it's in position III. Also before and after. No voltage to it. So i'm guessing it's either a ground, relay or bad ignition.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IronOutlawz »</TD></TR><TR><TD CLASS="quote">nope still havent fixed the problem. im sick of screwin with it so im gonna wire a push button on it. but in the mean time if anyone has fixed a problem like this i sure would like to know.</TD></TR></TABLE>
Let me know how your gonna hoook up that push button.
But on what side, before the ingniton switch or after it ?
Its the clutch switch. Same **** happened to me when I was o-so-happy and about to go on a date. Needless to say the rest of the night sucked, and so did the following few days.
Got up under the dash, the little blue button cover was shattered that engages when you push the clutch in. Im a big dude so it was hard for me to get down there and jump the wires, so instead I jammed a bolt in the hole on top of the clutch pedal, viola, car started again.
Did the same for my damn brake lights a month before to!
LOL!
LOL!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IronOutlawz »</TD></TR><TR><TD CLASS="quote">its not the clutch switch. i jumped it and i told tuan to do it to and it didnt work for both of us.</TD></TR></TABLE>
Yup!!! so frustrating. When you think you found the problem, and it's not.
