Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Solo II class question
Old Jan 11, 2002 | 09:08 AM
ak-s2000's Avatar
Default Solo II class question
I have either run in GS or CSP in my ITR and GSR and now that I have put the Mugen suspension on the ITR it will fall in the CSP class. Well, the ITR in CSP is out classed by the lightweight CRX's. So, I am considering the Street Touring (STX) class BUT I still want to use my R-compound Kuhmos. My question is, what is the specific class in ST with R tires? Thanks.
Old Jan 11, 2002 | 09:13 AM
StageOne's Avatar
Default Re: Solo II class question (ITR_0207)
both STS and STX are street tire classes. If you wnat to use Kumho V700s, then you will have to run SM (Street Modified) or your previously mentioned CSP
Old Jan 11, 2002 | 09:14 AM
Flux's Avatar
None (as far as I know).
I plan on running my R in STX. Sure, you have to give up the R compound - but it gives us a place to play and be competitive...
Old Jan 11, 2002 | 09:16 AM
Crazydave's Avatar
Default Re: Solo II class question (Flux)
What about ST-R or is that now obsolete class
how about street mod?
Old Jan 11, 2002 | 09:22 AM
celica73's Avatar
New User
Default Re: Solo II class question (Crazydave)
STR was dropped for 2002 - lack of interest. Even if it were still around the ITR would not qualify due to the no LSD restriction.
So, STX on street tires or SM and CSP for race tires.
Get some nice cams and make the jump to prepared, then you can run real race slicks (not DOT approved ones).
Scott
Old Jan 11, 2002 | 09:24 AM
smokin rubber's Avatar
Default Re: Solo II class question (celica73)
whats the deal with stx, whats is allowed? beyond sts
Old Jan 11, 2002 | 10:09 AM
slowSER's Avatar
Default Re: Solo II class question (smokin rubber)
STX
1) All allowances in STS would carry over, including street tires, rim restrictions,
emissions, etc.
2) All restrictions regarding body type carry over.
3) Engine size allowance: up to 5.1, normally aspirated and 2.0, forced induction
(single turbo or supercharger).
4) Only factory limited slip differentials (LSD) are allowed on AWD vehicles, as defined in Section 12.4. For 2WD vehicles and AWD vehicles that did not come
with any type of limited slip differential (including center differential or transfer case), a single aftermarket LSD may be added.
5) High flow catalytic converters are allowed, but must attach within six inches
of the original unit.
6) Alternate motor mounts and/or engine locators (bobble struts) sold by the
vehicle's manufacturer or their Motorsports subsidiary or affiliate
(Chrysler / Mopar, Toyota / TRD, Honda/Mugen, etc.) are allowed.
7) Alternate driver and front passenger seats are allowed, but they cannot be
constructed of a solid outer shell and must have a suspended bottom cushion
and be fully upholstered.
8) Brake rotors and calipers are unrestricted, but must attach to the original
attachment points.
9) Additionally excluded cars: BMW M3 (E36 and E46), BMW M5 (all).
Old Jan 12, 2002 | 01:08 AM
Caffeine Slug's Avatar
Can't you stay in SM when you replace cams?
Old Jan 12, 2002 | 08:16 AM
jasyatz's Avatar
Default Re: Solo II class question (Caffeine Slug)
From an interpretation stand point that's a tough question. You ARE allowed an engine swap based on the SM rules AS they are written, but with the rules BASED on the SP class structure and modifications list, that would mean a cam swap is NOT allowed. BUT putting a set of ITR cams in your B16/B18 motor would be from the same manufacturing line so....
Basically it's anybody's guess at this point...
I'd let it slide in our region
Old Jan 12, 2002 | 08:46 AM
celica73's Avatar
New User
Default Re: Solo II class question (conetoy)
cam swaps are most definately allowed in street mod. The only requrement is that the engine be from the same manufacturer as the chassis. I know a fellow with a 300hp 83 Celica that runs (legally) in SM. It has a custom turbo, cam, etc. You name it. The car also passes the IM230? emissions tests with room to spare (the one that is done under load on a dyno).
Scott
Old Jan 13, 2002 | 10:20 AM
jsi's Avatar
jsi
SM rules:
Drivetrain and related components (induction, ignition, fuel systems, etc.) are unrestricted except for the following limitations:
Engine must be from the same manufacturer as the body (Toyota/Lexus, Nissan/Datsun, Honda/Acura, etc.) Swaps involving makes related only at corporate level (e.g. Ford/Volvo, Renault/Nissan) are not recognized.
Maximum displacement:
Forced induction -
3.0L (OHC engines)
4.0L (pushrod engines)
Normally aspirated -
6.0L
Rotary engines (all) -
1.5L
ITRmike98
25
Sep 4, 2002 09:19 AM
Todd00
11
Jun 20, 2002 12:56 PM
Nuts
Mar 21, 2002 02:36 PM
Ausmith
23
Feb 15, 2002 07:08 PM
travis
15
Jul 23, 2001 07:40 PM
