B16a1 Valve Adjustment Specs
Hey guys, my valves are ticking a bit on my B16a1. My friend told me that the clearance was suppose to be 0.08 for intake and 0.06 for exhaust. Is this correct? If not, what are the correct clearances?
Thanks
Thanks
That is not correct. The clearances should be like below
Intake .006 - .008
Exhaust .007 - .009
I usually set mine towards a tighter spec, but do not tighten them to much. I usually get the intake to grab hard on the .007 but that the .006 still has a grip on the feeler guage
Intake .006 - .008
Exhaust .007 - .009
Thank you very much. That is muchly appreciated. Now i can go yell at the mechanic for setting it at 0.17. thats right...... 0.17
Well there are two different measurements on each feeler guage. Mine has a number on the top and one on the bottom of the feeler guage. Maybe the .17 was in a different incriment
If not, then damn the bastard that set your valve lash that big
wagon-r
Jun 11, 2013 09:32 AM
laloquera916
11
Sep 1, 2010 05:15 PM
conceptEG
Aug 23, 2003 08:11 AM
