Suspension Upgrade for my GSR
Old Jan 17, 2005 | 11:09 PM
integra714's Avatar
Default Suspension Upgrade for my GSR
I own a 95 GSR and I was looking to upgrade my suspension, I want to upgrade with new shocks and springs. Im looking for good quality, smooth ride and also better performance. I dont have a set budget so you can throw anything at me as long as its reasonable. Let me know what you think would be the best setup and how much it would cost. Thanks in advance.
Old Jan 17, 2005 | 11:55 PM
JAI-DM's Avatar
Default Re: Suspension Upgrade for my GSR (integra714)
Not to give you the usual answer but a quick search for "integra suspension" or "DC2 suspension" should get you answers quicker than waiting for opinions. Check it out, good luck with your upgrades!!!
Jai
Old Jan 18, 2005 | 12:19 AM
integra714's Avatar
Default Re: Suspension Upgrade for my GSR (INTEGRAJAI)
thanks I tried to search but i guess i did the wrong key words for the search
Old Jan 18, 2005 | 12:28 AM
OneDirection's Avatar
Here's what I did and am pretty happy with it.
Ground Control Sleeves
Koni Yellows
Comptech Rear Sway
It seems to be a pretty standard setup. For me the standard GC springrates seem about right, but others like insane springrates.
Old Jan 18, 2005 | 12:22 PM
integra714's Avatar
bump
Old Jan 18, 2005 | 12:24 PM
l2Y4N's Avatar
a good mild set up would be Eibach sportlines and some Koni yellows, fully adjustable height and softness
Old Jan 18, 2005 | 12:52 PM
patmcd's Avatar
Default Re: Suspension Upgrade for my GSR (integraTracer)
Depending on your budget, I would suggest omni coilovers. If you need somethign cheaper I would go with sportlines and some nice shocks.
Old Jan 18, 2005 | 12:59 PM
Lewie's Avatar
I'm here for the gangbang!
There's a new suspension forum, try that.
Old Jan 18, 2005 | 01:05 PM
slowkaos's Avatar
Default Re: (Lewie)
Here is what I have and I love it.
KYB VR2 struts
Eibach Sportline Springs
Energy Suspension bushing kit
Old Jan 18, 2005 | 01:06 PM
FireMedic's Avatar
Default Re: Suspension Upgrade for my GSR (patmcd)
I rode in a guys Integra with Tein Type Basics a couple weeks ago and was happy with the ride, even though its not adjustable. I personally have ITR Springs all the way around on new OEM shocks. I will probably get Tein SS's or GC standard spring rates & Koni yellows.
I have a comptech strut bar up front and am getting ready to purchase the comptech rear antisway/tiebar combo, and some sort of rear strut tower bar. I think it will be a good setup for my daily!
Old Jan 18, 2005 | 01:13 PM
Funkin Flux's Avatar
Tokico illuminas and eibach sportline. cheap and wont do u wrong.
Old Jan 18, 2005 | 01:28 PM
Elemental's Avatar
a lot of guys on here run koni yellows on ground control coilover sleeves. good setup adjustable height and dampening.
Old Jan 18, 2005 | 03:59 PM
integra714's Avatar
Default Re: (Elemental)
Old Jan 18, 2005 | 04:05 PM
DAguyLS's Avatar
i've had eibach sportlines and they provide a decent drop, i think something like 2.25/2....f/r
or the pro kit from eibach for a less agressive drop.
Koni Yellows to pair up with them
Old Jan 18, 2005 | 04:06 PM
Moogen Powah's Avatar
Default Re: (slamdLScivic)
Ground Control's with Koni Yellows.
Old Jan 18, 2005 | 04:20 PM
gsrboi80's Avatar
Default Re: (Moogen Powah)
Tein SS's
Old Jan 18, 2005 | 10:51 PM
integra714's Avatar
Default Re: (gsrboi80)
what do you guys think about skunk2 coilovers with tokico blues
Old Jan 18, 2005 | 11:11 PM
Default Re: (integra714)
The Tokico Blues will likely not be able to handle the spring rates and your desired drop. AGX's, Illuminas, or Koni Yellows will be a better comination with the Skunk2 Coilovers.
Old Jan 18, 2005 | 11:58 PM
integra714's Avatar
oh I see cause I want the skunk2 coiloer I just need to figure out what shocks to use
Old Jan 19, 2005 | 09:24 AM
integra714's Avatar
bump ^^
Old Jan 19, 2005 | 09:47 AM
redGSRguy's Avatar
I've heard good things about the GC sleeves. I'm running comptech springs on Koni yellows and will be swtiching to GC once I can find a good deal and a good spring rate to get.
Old Jan 19, 2005 | 09:50 AM
integra714's Avatar
Default Re: (redGSRguy)
where did you purchase your koni yellow, how much were they and how much do you like them
Old Jan 19, 2005 | 12:44 PM
integra714's Avatar
up up
Old Jan 19, 2005 | 04:00 PM
integra714's Avatar
thanks ^^^
Old Jan 19, 2005 | 04:21 PM
daLixz25's Avatar
I'm running the following:
itr rear lcas
eibach sportlines
itr-spec koni yellows
itr rear sway
and about to order advanced techniques lower tie bar
Couldn't be happier with the ride height and comfort level.
