crx shocks on an eg?
the front struts are a little shorter, and are smaller where they go into the fork that goes over the axle, but the rears are the exact same thing
fronts WILL need to use the stock EF forks. Rears will bolt in however the EG rear LCA is a little thinner than an EF so the it will get crushed a little but it will work, that actually the setup I'm using right now.
BTW the rear only work if its a 89-91.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastwanabe »</TD></TR><TR><TD CLASS="quote">fronts WILL need to use the stock EF forks. Rears will bolt in however the EG rear LCA is a little thinner than an EF so the it will get crushed a little but it will work, that actually the setup I'm using right now.
BTW the rear only work if its a 89-91.</TD></TR></TABLE>actually the control arms are the exact same, the 96-00 arms on the rear are a little thinner
hb_guy
Nov 7, 2005 08:51 PM
VSM EXtasy
May 6, 2005 11:56 PM
