oil feed and oil pressure
Old Jan 17, 2005 | 09:20 PM
PHOBIA's Avatar
Default oil feed and oil pressure
i was wondering,when im going to turbo my car people sed i can get the oil to supply my turbo from a blank spot right near the oil filter,well i was also told that my oil pressure auge would be using the same spot.could i just get like a 3 way splitter? or something along those lines to supply oil to my tubo and still give me accurate readings? thanks for the help...
Old Jan 17, 2005 | 09:22 PM
D-t's Avatar
D-t
Default Re: oil feed and oil pressure (PHOBIA)
I believe you can get an oil take off fitting.
TunerToys.com has them for like 20 bucks
Old Jan 17, 2005 | 09:27 PM
PHOBIA's Avatar
i wil check with them, i auctually bought my u bends and such from them to make my charge ic pipes.so does it just thread into the block with like too nipples or something along those lines?
Old Jan 17, 2005 | 09:32 PM
D-t's Avatar
D-t
Default Re: (PHOBIA)
Yeah just screw in the fitting, and boom you should be set.
Old Jan 17, 2005 | 09:35 PM
PHOBIA's Avatar
ok checked out tuner toys and they only have a single and a double port.the only problem is.one end goes into the block,the other end is for the factory sensor,and the other leaves only the one plave for either a gauge or oil feed not 2.i was wondering,would it be possible or a good idea for the matter to buy this fitting and then buy another kind of splitter to come off the fitting?any suggestions would be great
Old Jan 17, 2005 | 09:41 PM
D-t's Avatar
D-t
They also have a firewall kit, in which you can tee off of that.
Old Jan 18, 2005 | 05:59 AM
DaX's Avatar
DaX
Loved
Community Favorite
Ok, I'm prepared for the flaming, but I honestly think the ONLY way you should feed oil to the turbo is through a sandwich plate that goes between your block and your oil filter. This way you are feeding your turbo nice FILTERED oil, and you don't risk stripping/cracking the fitting on the back of your block. I read the stories, didn't think it could happen to me, then BAM! cracked mine. Now I run the GE adapter.
Old Jan 18, 2005 | 06:02 AM
EJ1 wilcox's Avatar
Default Re: (slow poke)
IMO a firewall kit is the way to go...
That way you can have it all right there on your firewall and if you have a problem it's easy to work with...
When I first installed my turbo I had a small leak in one of my fittings and it was super easy to fix because the oil feed was right there... Then again, I hate doing anything on the back of the block, it's such a pain to get to...
Anyways, there are other options but this is just the one that I prefer...
A sandwich kit would be my other favorite option, but then again, I hate having fittings on the back of the block...
Old Jan 18, 2005 | 06:12 AM
GDM Z28's Avatar
Default Re: (EJ1 wilcox)
oil sandwich hands down...i have one and i love it...the back of the block is weak i dont wana **** around near it.
Old Jan 18, 2005 | 06:46 AM
gt35r's Avatar
Default Re: (civicflnum1)
its all about the vtec oil pressure sensor. Use a T fitting from there and you are good to go. Easy to work with and you get good oil pressure.
Old Jan 18, 2005 | 06:53 AM
PrettyLude's Avatar
pm stan, he has everything your looking for when it comes to fittings
Old Jan 18, 2005 | 06:58 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: (gt35r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gt35r &raquo;</TD></TR><TR><TD CLASS="quote">its all about the vtec oil pressure sensor. Use a T fitting from there and you are good to go. Easy to work with and you get good oil pressure. </TD></TR></TABLE>
Are you talking about tapping for oil from the head? Not a good idea...
Old Jan 18, 2005 | 07:02 AM
GDM Z28's Avatar
Default Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">
Are you talking about tapping for oil from the head? Not a good idea...</TD></TR></TABLE>
lol you beat me to it. its gonna draw pressure from the sensor and you will have vtec problems....
Old Jan 18, 2005 | 07:20 AM
PHOBIA's Avatar
wow thanks guys,quick question about this sandwich fitting.i know this sounds stupid but im new to the turbo ****.doe sit just creat a gap between you block and the oil filter and then have a fitting some were inbetween? i like the fire wall idea.again thanks for all the help.
Old Jan 18, 2005 | 07:23 AM
GDM Z28's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHOBIA &raquo;</TD></TR><TR><TD CLASS="quote">wow thanks guys,quick question about this sandwich fitting.i know this sounds stupid but im new to the turbo ****.doe sit just creat a gap between you block and the oil filter and then have a fitting some were inbetween? i like the fire wall idea.again thanks for all the help.
yes it goes between the filter n block n gives u little ports
balbowskie
Feb 17, 2012 06:47 PM
jononioo
Mar 17, 2006 07:10 PM
wade
Oct 10, 2004 07:38 PM
GruvyTune
Feb 5, 2002 03:27 PM
slingshotsi
Sep 9, 2001 06:11 PM
