changing fuel filter
Old Jan 17, 2005 | 07:32 PM
2kstreetcivic's Avatar
Default changing fuel filter
was wondering how to change and fuel filter and what kind of warnings or precautions I should take..thanks
Old Jan 17, 2005 | 09:21 PM
SpdFrk's Avatar
Default Re: changing fuel filter (2kstreetcivic)
1. put rags around/under the filter
2. relieve fuel pressure
3. unscrew the top bolt
4. unscrew the threaded fitting(fead line) at the bottom of the fuel filter
5.then use a socket w/extension to remove the filter clamp bolt and then remove the filter.
Installation is reverse just make sure you use new sealing washers on both sides.
Old Jan 17, 2005 | 09:31 PM
Default Re: changing fuel filter (SpdFrk)
new sealing washers??..so I have to go out and buy new washers??..rubber washers??
Old Jan 17, 2005 | 10:01 PM
triple_s1x's Avatar
Most filters already come with the washers, atleast the oem one does.
Old Jan 18, 2005 | 06:13 AM
PrettyLude's Avatar
they are metal washers
Old Jan 18, 2005 | 07:42 PM
Default Re: (PrettyLude)
cool thanks alot guys
redlinez_r_us
Sep 16, 2009 12:02 PM
ALMXDUPINTEGRA
May 17, 2005 03:06 PM
WayneGro
Oct 24, 2003 04:58 AM
hmongboyLS
Oct 4, 2003 12:08 AM
CivilizedCiv
Aug 22, 2002 08:22 AM
