Is there a differences btwn a sohc and dohc Factory FPR??
Old Jan 17, 2005 | 06:09 PM
Supahr_Ed's Avatar
Default Is there a differences btwn a sohc and dohc Factory FPR??
Like the question says, its there a diffence btwn a 1.5L sohc and a 1.8L dohc Factory FPR? I know the engines run on differ pressures through vaccum but is there a actual difference, besides looks? THX
Old Jan 18, 2005 | 02:32 AM
civic-4-ges's Avatar
Default Re: Is there a differences btwn a sohc and dohc Factory FPR?? (Supah_Eg6)
I believe they are produced to allow for different pressure to begin with, so different parts.
You could always compare part numbers on the Honda/Acura parts sites just to make sure!
Old Jan 18, 2005 | 06:10 PM
Supahr_Ed's Avatar
well i would say they would have different part number becuase of the way the vacumm line is angled. different cars have the line pointed different directions.
I tried searching but couldnt find anything on HT...ill try again
Old Jan 19, 2005 | 05:28 AM
JimBlake's Avatar
Default Re: (Supah_Eg6)
Not even all DOHC are the same... For example 3rd-gen Integra LS & GSR have different fuel pressures, & they're both DOHC.
Old Jan 19, 2005 | 10:23 PM
Supahr_Ed's Avatar
Default Re: (JimBlake)
i do know they run on different fuel pressures but i assume it was through the vaccumm of the actual engine its on....but is there a difference on the ACTUAL DIAPHRAM in the FPR?
I have a 1.5L on my 2.0L and idles low on warm up...not sure if its the FPR....
Old Jan 20, 2005 | 03:51 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Supah_Eg6 &raquo;</TD></TR><TR><TD CLASS="quote">...but is there a difference on the ACTUAL DIAPHRAM in the FPR?</TD></TR></TABLE>YES.
Old Jan 21, 2005 | 12:16 PM
Supahr_Ed's Avatar
Ok, i go wit your advice, i change the FPR back, thanks again
mugencx
Oct 8, 2007 08:02 PM
Mark80
May 14, 2006 08:01 PM
JDM B16A
Mar 27, 2006 08:34 PM
