Confused PLEASE HELP
hey guys ive been tryin to get my hatch with a built ls goin for weeks now it was runnin decent and then one day i started it up ir ran for a few secs and died now it wont start. its not the main relay( well its not the only problem) because the injectors, dist., ecu, AND main relay are not getting power. i also looked at the main fuse and it appears fine but i havent checked it. any one with similar problems or any other ideas and the battery is brand new
You need to first find out where the power is and isn't.
Then once the electrical side is taken care of look into things like
replacing distrib, altinator, has your motor sized up? Is there enough fuel?
Go through the check list first.
Good luck!
Good luck!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a11mtrhatch »</TD></TR><TR><TD CLASS="quote">and if i do</TD></TR></TABLE>
then check to make sure it hasn't immobilized your ignition...
smbignick
Aug 18, 2013 01:47 PM
