How do you know if you have a bad wheel bearing? (Noise from front right on turns to right only...)
I thought a similar topic was here yesterday, but I can't find it...
What were the ways to diagnose bad bearing, or what is causing weird noise only on right turns, a kind of grindage noise.....? From front axle/ wheel area... Passenger's side...
No problem Black R. Since I might have the same problem, I'm interested to hear the answer to this question too.
Here's a similar, more specific question...
If the noises are all indicative if a bad wheel bearing, but the wheel is completely solid when you jack it up and wiggle it (I mean completely solid), does this mean it's not the bearing?
