Clutch fluid?
Old Jan 17, 2005 | 02:32 PM
EJ8 GSR-T's Avatar
Default Clutch fluid?
Hey, so i find myself practically putting in more clutch fluid into my car than i do gas, so im guessing theres a small leak or something, but i was just wondering if anyone else has had a similar problem? Im driving a 98 civic ex
Old Jan 17, 2005 | 02:34 PM
=GAME='s Avatar
Default Re: Clutch fluid? (userdead626)
bad master cylinder?
Old Jan 17, 2005 | 02:51 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Clutch fluid? (=GAME=)
Check for leaking fluid under the dash, where the pedal connects to the master cylinder & goes through the fire wall. That **** is nasty & can melt all the plastic parts under there & soak into your carpet. If the MC is leaking, replace it. It is really easy & only cost about $40. Once your done, blead the clutch & go...
Old Jan 17, 2005 | 02:55 PM
nub's Avatar
nub
clutch master cylinder or slave cylinder, could also be the hose from the resevior to the master cyl. just look for the the wet spot
Old Jan 17, 2005 | 03:07 PM
EJ8 GSR-T's Avatar
Default Re: Clutch fluid? (nub)
under the dash, there is absolutely no leaking....where else would i look?
Old Jan 17, 2005 | 03:27 PM
snoochtodanooch's Avatar
maybe the bleeder valve is open? you leaving fluids on the ground?
Old Jan 17, 2005 | 03:41 PM
EJ8 GSR-T's Avatar
Default Re: Clutch fluid? (snoochtodanooch)
not that i can see, its weird because the resivour for the fluid is like 2 oz. so it must be a very small leak, but man its so annoying when im at a stoplight and oops gotta open my hood and add fluid......
JDMswagSerf
Dec 10, 2013 09:47 PM
WiLLMaTiX
May 3, 2004 03:24 PM
aengnr1
Jun 16, 2003 12:23 PM
94TeGsR
Jan 14, 2003 09:00 AM
cannan
Oct 30, 2001 11:31 AM
