81.50mm or 81.75mm ctr pistons on b16a2????
Old Jan 17, 2005 | 12:41 PM
kenepo_vtec's Avatar
Default 81.50mm or 81.75mm ctr pistons on b16a2????
I can get some ctr pistons in 81.50 or 81.75mm, to put in a b16a2 engine. I need to know if the engine will support one of this bore...let me know your opinions to complete my all motor crx project.
Old Jan 17, 2005 | 02:12 PM
notstock93's Avatar
Default Re: 81.50mm or 81.75mm ctr pistons on b16a2???? (kenepo_vtec)
They make 81.75 OEM pistons?
I thought they topped out at 81.5.
At any-rate, just go 81.5mm
Old Jan 18, 2005 | 08:39 AM
BigHeadKid's Avatar
if those 81.75 are ctr's, they're most likely the .25 over sort. this is fine and you'll have plenty of room in your block. you will need to have your block machined and bored for the larger pistons. bigger is always better too in my opinion. im not sure if you have to mod your wrist pins to accept the ctr slugs, but even if you do, it wont be expensive and definitely worth it! good luck
Unphzd
Oct 6, 2011 12:07 AM
2ToneEM1
Feb 26, 2008 04:10 PM
SLEPTONEG6
Dec 22, 2003 12:10 PM
Mar_DC2
May 17, 2003 08:28 PM
