Potenza RE010 (OEM Type R tire).....opinions?
Old Jan 17, 2005 | 11:15 AM
TheGSRGuy's Avatar
Default Potenza RE010 (OEM Type R tire).....opinions?
What does everyone think of the OEM Type R tires, the Bridgestone Potenza RE010? I did some reading on Tire Rack and they seem to be a fairly sticky tire, but many complain that they shred through them in 20,000 miles or less. They're also pretty pricey, at $130/tire. (I can get two Azenis, or two Ecsta Supra 712s)
I'm currently on 205/55R15 tires and they rub in the fenderwells with my 0.75" drop. The dealer advised me to get either a 205/50R15 or the stock 195/55R15.
The rubbing is getting pretty bad...to the point that I'm through the fenderlining and touching metal when the steering wheel is at lock.
Old Jan 17, 2005 | 11:23 AM
kepani's Avatar
Default Re: Potenza RE010 (OEM Type R tire).....opinions? (TheGSRGuy)
in my personal humble opinion, they are the best tires (non-track) i have ever driven on for stock itr wheel size (15x6.0). although they are expensive, their dry grip is excellent. some others report decent performance in the rain, but from what i remember when i had them, they were a little *uneasy* in the rain.
yeah, they do wear out fast. but then again, that's somewhat of a trade-off for such grippy tires.
there's a reason why they were OEM on both the itr AND nsx.
kepani
Old Jan 17, 2005 | 11:25 AM
RTW DC2R's Avatar
what size rim do you have? im pretty sure lots of people here have larger tires/wheel combos and dont rub even with a slight drop like you have.
as far as the RE010 goes, its fairly "sticky" and like any tire if you beat the **** out of it then its not going to last too long, hence ~20K miles. if we are talking about mounting these on stock ITR sized rims, then 195s seem to have better turn in.
Old Jan 17, 2005 | 11:26 AM
Bbasso's Avatar
Default Re: Potenza RE010 (kepani)
BINGO! for stock size wheel the RE010s are the best.
and I agree with kepani's Opinion
Old Jan 17, 2005 | 11:27 AM
Philly_NBP_R's Avatar
Default Re: Potenza RE010 (Bbasso)
Me too - Re010's are amazing on stock wheels...
Old Jan 17, 2005 | 11:30 AM
Bbasso's Avatar
23.5" (195/55-15) Overall Diam.
the 205/55-15 what tire are you using?
Old Jan 17, 2005 | 11:38 AM
Dave_B's Avatar
As soon as I burn through my current set of tires I'll be purchasing a set.
Old Jan 17, 2005 | 11:52 AM
TheGSRGuy's Avatar
Default Re: (01PY0559)
I actually have a GS-R coupe, but I have a full ITR suspension setup (LCAs, springs, shocks, F&R strut bars). This drops me to an ITR ride height basically.
I have Continental ContiExtremeContact tires right now...got them about 16 months ago when I used to live in the Midwest. They're an "all-season ultra-high performance" tire.
I want something stickier and not quite as wide. The OEM ITR tires seemed to be a good place to start, but I'm open to other suggestions. $130/tire is fine, as long as I know I'm getting my money's worth. I need something sticky for the twisty mountain roads.
Old Jan 17, 2005 | 12:03 PM
Dave_B's Avatar
Another option you have is the Falken Azenis. These provide great dry traction and depending on who you talk to so-so wet/snow traction.
Old Jan 17, 2005 | 12:22 PM
TheGSRGuy's Avatar
I'm not too worried about snow traction since I live in Arizona.
Azenis are cheap and sticky, but they wear out pretty fast.
Old Jan 17, 2005 | 12:30 PM
Bbasso's Avatar
Default Re: (TheGSRGuy)
23.9" for your tire, Overall Diam.
23.5" (195/55-15) Overall Diam. for RE010s
I don't see how you have any rubbing issues... hrmmm
Old Jan 17, 2005 | 12:31 PM
Bbasso's Avatar
You might want to jack up the car and start poking around to make sure nothing is bent, missing or just hangin low.
Old Jan 17, 2005 | 12:45 PM
TheGSRGuy's Avatar
Default Re: (Bbasso)
Nah it's all fine, I actually took it to the dealer and he said that a 205/55R15 is too wide for a Type R (or car with Type R suspension). The tech recommended 205/50R15 or the stock 195/55R15 sizes.
Old Jan 17, 2005 | 12:53 PM
mikestypeRR's Avatar
Default Re: (RTW DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">what size rim do you have? im pretty sure lots of people here have larger tires/wheel combos and dont rub even with a slight drop like you have.
as far as the RE010 goes, its fairly "sticky" and like any tire if you beat the **** out of it then its not going to last too long, hence ~20K miles. if we are talking about mounting these on stock ITR sized rims, then 195s seem to have better turn in. </TD></TR></TABLE>
read man... its fundamental.
[QUOTE=TheGSRGuy]
I'm currently on 205/55R15 tires QUOTE]
Old Jan 17, 2005 | 01:33 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheGSRGuy &raquo;</TD></TR><TR><TD CLASS="quote">What does everyone think of the OEM Type R tires, the Bridgestone Potenza RE010?</TD></TR></TABLE>
Excellent tire for overall performance, particularly for razor sharp handling. Treadlife is decent (20K is actually pretty good). Price is higher than some other tires. My first choice for street driving the ITR (in the stock 195/55-15 size). RE010
Old Jan 17, 2005 | 01:42 PM
1GreyTeg's Avatar
Default Re: Potenza RE010 (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">
I'll second,, err third or fourth that
Old Jan 17, 2005 | 01:49 PM
machgo5go's Avatar
I love it the best OEM made for our R.
I just wish I could have the OEM JDM 16's in the state, not the NSX one.
Old Jan 17, 2005 | 01:50 PM
KayOs's Avatar
Default Re: Potenza RE010 (1GreyTeg)
I have to agree with the consensus here. The RE010 are great tires when used in conjunction with OEM rims and utilizing the OEM stock size.
Old Jan 17, 2005 | 03:03 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheGSRGuy &raquo;</TD></TR><TR><TD CLASS="quote">Nah it's all fine, I actually took it to the dealer and he said that a 205/55R15 is too wide for a Type R (or car with Type R suspension). The tech recommended 205/50R15 or the stock 195/55R15 sizes.</TD></TR></TABLE>
A 205/55 tire should be no wider than the same tire in a 205/50 size. However, some tires tend to run wider than their width rating would otherwise indicate (e.g., the Azenis).
Old Jan 17, 2005 | 03:22 PM
RTW DC2R's Avatar
Default Re: (mikestypeRR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikestypeRR &raquo;</TD></TR><TR><TD CLASS="quote">
[QUOTE=TheGSRGuy]
I'm currently on 205/55R15 tires QUOTE]</TD></TR></TABLE>
Maybe you should learn to read, stunna. I said RIM not tire. By the way, nice contribution to the thread
Old Jan 17, 2005 | 03:33 PM
TheGSRGuy's Avatar
Default Re: (Padawan)
Padawan, don't forget that the aspect ratio actually does influence the width of the tire.
Regardless, 205/55R15 doesn't fit very well.
Old Jan 17, 2005 | 03:42 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheGSRGuy &raquo;</TD></TR><TR><TD CLASS="quote">Padawan, don't forget that the aspect ratio actually does influence the width of the tire.</TD></TR></TABLE>
The width of the tire, when combined with the aspect ratio, influences the overall diameter of the tire, but a tire marked 205 should be 205 mm wide, whether it's aspect ratio is 50% or 55%.
Old Jan 17, 2005 | 04:05 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheGSRGuy &raquo;</TD></TR><TR><TD CLASS="quote">don't forget that the aspect ratio actually does influence the width of the tire.</TD></TR></TABLE>
How?
If the tire tread is supposed to be 205 mm wide, then it's supposed to be 205 mm wide, regardless of aspect ratio...
Old Jan 17, 2005 | 05:56 PM
TheGSRGuy's Avatar
Default Re: (nsxtasy)
Yeah sorry, didn't phrase that correctly.
Asmar
Jul 9, 2013 05:19 PM
candy eg
Aug 26, 2006 10:37 PM
tinman24
10
Jul 15, 2006 12:14 AM
JDM Factor
Jun 7, 2005 01:28 AM
