4spd to a 5spd
Old Jan 17, 2005 | 10:13 AM
90civilac's Avatar
Default 4spd to a 5spd
Hey I was wondering if I need new axels if I install a 5spd into my 1990 civic hb. It currently has a 4 spd. If I do need new axels what would be good axels to get. Also what are your preferences in exhaust systems
Old Jan 17, 2005 | 10:20 AM
4drEF's Avatar
Keyboard Humorist
Default Re: 4spd to a 5spd (90civilac)
Same axles.
Old Jan 17, 2005 | 10:35 AM
Dwight Schrute's Avatar
Default Re: 4spd to a 5spd (4drEF)
the std axels are different than the dx/si axles
Old Jan 17, 2005 | 10:41 AM
EFRue57's Avatar
Default Re: 4spd to a 5spd (drewthomas14)
they are different but they will work. all you have to do is change out one of the axle seals. i don't remember if it is the passenger or the drivers side that you have to change out, but all you need to do is just cross reference part numbers and you should be able to find out at any auto place like auto zone, pep boys, ect...
Old Jan 17, 2005 | 10:52 AM
eumoria's Avatar
i have a STD that I put a 5spd CRX DX transmission on. Same axles.
Old Jan 17, 2005 | 10:57 AM
Iceycrx's Avatar
Default Re: 4spd to a 5spd (eumoria)
I had a 90 HF with a 4spd in it and the HF axles worked perfect on them
Old Jan 17, 2005 | 10:59 AM
EFRue57's Avatar
Default Re: 4spd to a 5spd (Iceycrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Iceycrx &raquo;</TD></TR><TR><TD CLASS="quote">I had a 90 HF with a 4spd in it and the HF axles worked perfect on them</TD></TR></TABLE>
hf/std axles are the same, but different from dx/si axles. so i guess if you wanted an hf tranny, which is a 5 speed, it would work perfectly, but get ready for really long gears.
Old Jan 17, 2005 | 11:08 AM
SinisterCRX's Avatar
I hope you got the Si 5 speed. HF gears are nice for MPG, long as heck but the Si's gear ratio is comparable to the EX/Si hyrbids that a lot of people do.
My preference, I like GReddy. I'd recommend getting a local shop to do one though, much cheaper.
Old Jan 17, 2005 | 01:18 PM
4drEF's Avatar
Keyboard Humorist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drewthomas14 &raquo;</TD></TR><TR><TD CLASS="quote">the std axels are different than the dx/si axles</TD></TR></TABLE>
Yes they are, but they are only different on the hub side.
They will plug into the 5 spd tranny no problem... well.. unless it's a ZC tranny.
ZC tranny has the different diff. Change out the diff and you can use your stock axles (do not use the ZC intermediate shaft).
Old Jan 18, 2005 | 10:14 AM
90civilac's Avatar
What kind of 5spd is in a prelude
Old Jan 18, 2005 | 10:21 AM
EP3_05's Avatar
One that will definitely not fit in a civic without a complete engine swap.
Old Jan 18, 2005 | 10:41 AM
90civilac's Avatar
Default Re: 4spd to a 5spd (91civic)
Why is that?
Old Jan 18, 2005 | 10:42 AM
90civilac's Avatar
WHat kind of motor would I need?
Old Jan 18, 2005 | 10:45 AM
EP3_05's Avatar
Preludes either came with
b20a=pre91 preludes
92-on either h23 or h22
Since your car has a d series none of these transmissions will bolt to your motor.
Here is a rule of thumb:
d series with d series
b series with b series
and so on...
firejackal
Jul 12, 2012 10:11 AM
SnakeBait
Jun 13, 2007 10:20 PM
pinecone
Mar 14, 2006 03:32 PM
Silent Knight
Jul 19, 2005 12:20 PM
Gant
10
Jan 8, 2005 05:31 PM
