code 12 on an hf please help! i needa besomewhere in a hour!
Old Jan 17, 2005 | 09:57 AM
Gumbey75's Avatar
Default code 12 on an hf please help! i needa besomewhere in a hour!
ok well my car doesnt start and its throwin a code 12. if someone can help on how to fix this please do asap!!!!
Old Jan 17, 2005 | 10:08 AM
Gumbey75's Avatar
Default Re: code 12 on an hf please help! i needa besomewhere in a hour! (Gumbey75)
please?
Old Jan 17, 2005 | 10:09 AM
Gumbey75's Avatar
oh yea i searched and i found but cant read what it says cause its small!
Old Jan 17, 2005 | 10:14 AM
DieMaster's Avatar
Needs to be About 20% Cooler
i have a HF manual lets see
there is no code 12 for a hf. count the blinks again. 12 is the EGR sensor an CA A/T modles like mine.
what ecu is it? what year? u have a engine swap? i need more info
Old Jan 17, 2005 | 10:28 AM
4drEF's Avatar
Keyboard Humorist
Default Re: code 12 on an hf please help! i needa besomewhere in a hour! (DieMaster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DieMaster &raquo;</TD></TR><TR><TD CLASS="quote">i have a HF manual lets see
what ecu is it? what year? u have a engine swap? i need more info</TD></TR></TABLE>
It's an HF so it does so have an EGR.
I don't think that would keep if from starting.
Was there any problems BEFORE this?
Does the fuel pump whiiiirrr for about 3 seconds when you put the key to the ON position?
Are you getting spark?
Are the grounds all good?
Old Jan 17, 2005 | 10:34 AM
Gumbey75's Avatar
Default Re: code 12 on an hf please help! i needa besomewhere in a hour! (4drEF)
ok i jus checked my ecu again and codes changed. its code 8 and code 20? i doichecek for all these things? when i tried to start it, it clicked. now it doesnt and changed codes. its a stock 88 hf. please help.
side note: when i was driing on the freeway yesterday it threw thechck engine light on?
Old Jan 17, 2005 | 10:57 AM
Gumbey75's Avatar
ok it was my battery! THANKS GUYS!
r90crxhf
May 19, 2014 07:26 PM
racingcrx
Jan 12, 2008 02:53 PM
theemaddhatterr
Aug 21, 2005 06:50 PM
Sampsonite987
Mar 27, 2004 06:47 AM
chirp2hrd
Jun 16, 2003 06:47 PM
