Suspension & Brakes Theory, alignment, spring rates....
Problem with new suspension setup
Old Jan 17, 2005 | 09:52 AM
Hyb's Avatar
Hyb
Default Problem with new suspension setup
im hearing a very weird noise coming from the driver side wheel. its like a knocking sound. it 'knocks' every wheel rotation, so at high speed its a loud noise low speeds its a stedy knocking. there is no sound from the other wheels. now, i changed the struts to tokico blues and put on a set of ground control coilovers. its not that low, bout an inch drop. any ideas what is causing this problem? thanks.
Old Jan 17, 2005 | 11:24 AM
artifex's Avatar
say it
Default Re: Problem with new suspension setup (Hyb)
my guess would be a loose nut/bolt somewhere along the way.. possibly the one at the top of the shock shaft. check them all, as even being a slight bit loose can cause LOUD noises once the suspension is loaded.
Old Jan 17, 2005 | 11:33 AM
Hyb's Avatar
Hyb
Default Re: Problem with new suspension setup (artifex)
everything is bolted up nice and tight. just checked that. im thinking it might be the bearings or something with the axle.
Old Jan 20, 2005 | 05:12 PM
Hyb's Avatar
Hyb
lug nuts were not properly torqued on there.
was using the 80ft/lbs instead of the the 90ft/lbs ratchet for the aftermarket aluminum rims.
Old Jan 21, 2005 | 01:00 AM
OneDirection's Avatar
You might want to grab some hubcentric rings while you are at it.
Old Jan 21, 2005 | 04:39 AM
.RJ's Avatar
.RJ
Default Re: Problem with new suspension setup (OneDirection)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OneDirection &raquo;</TD></TR><TR><TD CLASS="quote">You might want to grab some hubcentric rings while you are at it.</TD></TR></TABLE>
Whats this got to do with anything?
Not needed anyways. I've never used them, and never used 'hubcentric' wheels on track and never had a problem
Old Jan 21, 2005 | 12:03 PM
Sliced Beard's Avatar
Default Re: Problem with new suspension setup (.RJ)
ding ding ding!!!! we have a winner
Honda (along with many other manufacturers) uses conical self centering lug nuts in which hubcentric rings are not needed. Think about it, does an OEM Acura/Honda alloy wheel have an exact machined hub? No. They do not come with hubcentric rings from the factory because it is not necessary because hte lugs do it for you.
Old Jan 22, 2005 | 09:27 PM
Hub centric rings just make an additional assurance of alignment of the wheel and mating surfaces. Necessary? not likely. Hurting? Doubtful.
jayare05
Mar 22, 2009 11:24 AM
eastbayrep
Nov 26, 2006 12:15 PM
john d ftw
Oct 6, 2006 06:55 AM
civichbcx
Nov 1, 2005 10:54 AM
LSVTEC 91 Civic
18
Jul 25, 2005 09:34 AM
