Suspension & Brakes Theory, alignment, spring rates....
KYB strutc/shocks
Old Jan 17, 2005 | 07:17 AM
mountaindewguy's Avatar
Default KYB strutc/shocks
ok, simple. im on a budget. i just need something that will last me about a year, and the cheapest thing i could find was the KYB gr-2. my civic is lowered almost 2 inches, so i need something besides stock struts (the guy before me thought he would be cool and put just coilovers on with nothing aftermarket otherwise). so do you think the gr-2's would be worth the money? all opinions welcome!
Old Jan 17, 2005 | 07:36 AM
Radyjr's Avatar
Default Re: KYB strutc/shocks (mountaindewguy)
I got KYB and they have been good to get and my ride....... go with the KYB's
Old Jan 17, 2005 | 07:48 AM
SpoonmeSami's Avatar
Default Re: KYB strutc/shocks (Radyjr)
i have kyb agx's and i really like them. I say you save a little bit more and get these. I think you'll like the adjustability. I dont have any experience with the gr-2's tho
Old Jan 17, 2005 | 09:52 AM
Miss PSI's Avatar
If you are at 2" you could possibly could get a set of gr-2 to last awhile...
I had GR-2's on about 3" drop and I blew all four struts in 6 months... I would recommend the AGX
Old Jan 17, 2005 | 10:21 AM
Default Re: (Bitchinteg)
now if i get the agx's, when you say 'adjustable' does that mean adjust by height, stiffness, etc..? and do i have to adjust them, or can i put them on right out of the box? (i know no suspension lol)
Old Jan 17, 2005 | 12:39 PM
Default Re: (mountaindewguy)
With agx's you can adjust the dampening of each shock. The front's (depending on your car) are usually 4-way adjustable, and rears are usually 8-way adjustable. I think but im not sure that they come set at 2 front 4 rear. If you want you can just leave them like that and throw em on your car. Hope that helps.
Old Jan 17, 2005 | 01:00 PM
.RJ's Avatar
.RJ
Default Re: (SpoonmeSami)
They are not 4-way and 8-way adjustable.
They are 1-way (single) adjustable shocks. They adjust rebound (well, they're intented to only adjust rebound.... anyways) with the turn of the ****. Thats it. Single adjustment. There just happens to be 4 'stops' or positions of adjustment on the front and 8 in the rear.
</pet peeve> omg jdm aluminum 32-way adjuzzzztble!!11!2ELEVEN!!1
Old Jan 17, 2005 | 01:04 PM
Default Re: (.RJ)
oh ok thanks .Ok to the original poster, like i said i think they come set at 2 front/ 4 rear, the fronts just turn with a lil screw driver that is provided, and the rears have a little **** in the back. I suggest you play around with the settings and see which you like best. Not much difference tho
Old Jan 17, 2005 | 01:06 PM
.RJ's Avatar
.RJ
If they were 2-way adjustable they would adjust rebound and compression... or 3-way adjustable, low/high speed rebound and compression.... or 4-way adjustable, low/high speed rebound, compression, gas pressure (for a remote reservior). And so forth.
Old Jan 17, 2005 | 02:56 PM
Garcia-Racing's Avatar
I run the AGX's and am completely happy with them. In drag racing to adjustment is very useful, both in the front and the rear.
Old Mar 6, 2005 | 01:28 PM
JokerTypeR's Avatar
Default Re: (Garcia-Racing)
I've got AGX's on the rear. They kick ***. Spend the excess
https://honda-tech.com/zerothread?id=864170
This guy's sellin' 'em for about th best I've seen. (next to nopi.com, but I did a warehouse-pick-up with them)
I've done mountain runs and e-brake pulls. I'm satisfied with the roll (or lack of) and it goes will with my Skunk2's
Old Mar 6, 2005 | 04:28 PM
nonvtecD's Avatar
I have GR2's on my 2 inch lowered car, they have been nice and firm for a year now and show no signs of wear.
95_civic_sparco
13
Nov 18, 2004 10:54 PM
HONDA-2NR
Jan 28, 2004 06:30 PM
92LudeSI
Jan 15, 2004 08:55 PM
Dark Angel EK
Oct 5, 2002 10:44 PM
Cryptopsy
11
May 11, 2002 10:06 AM
