Bogging down, hesitating, cutting off
Old Jan 17, 2005 | 06:43 AM
professorman's Avatar
Default Bogging down, hesitating, cutting off
I have a 89 camry with 130k miles. I bought it with 128k miles. I was about to drive it this weekend, and it started bogging down like crazy. As soon as I stop, the revs would drop really low and then it just cut off. If I try to accelerate, it hesitates like it is not going anywhere. I was driving to the gas station and it just stumbles forward and shut off everytime I try to accelerate.
What are the most likely possibilities to be the cause of this problem?
What can I do to correct this problem?
I want as many suggestions as possible.
Could it be the spark plug wires? My 94 Accord was doing that 2 months ago and it was the spark plug wires. What do you think?
Thanks for your replies
P.S. I know this is an H-T fourm, but I think you H-T guys are more mature than the other boards on the internet
Old Jan 17, 2005 | 10:42 AM
Perfectionist's Avatar
Default Re: Bogging down, hesitating, cutting off (profroopchan)
Engine cold, or at operating temperature? Starts/idles OK? Needmore details, but...
I would check all the vacuum lines. Also could be caused by the mass air flow sensor (MAF if Toyato uses those...Honda uses a MAP sensor), and/or throttle position sensor.
Did it run when you bought it? Did it sit a long time?
Old Jan 17, 2005 | 10:50 AM
Default Re: Bogging down, hesitating, cutting off (Perfectionist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Perfectionist &raquo;</TD></TR><TR><TD CLASS="quote">Engine cold, or at operating temperature? Starts/idles OK? Needmore details, but...
Did it run when you bought it? Did it sit a long time? </TD></TR></TABLE>
Yes, it ran correct. I bought it in the begining of december, I just drove to Virginia with it last week from South carolina (7 hrs). It is cold here in virginia ~20F
how do i go about checking the vacuum lines?
how do i check the MAF sensor?
vtec_breh
Feb 27, 2011 06:30 PM
djdc2
May 4, 2006 08:33 PM
professorman
Jan 17, 2005 03:57 PM
95AccordGuy
Jul 16, 2004 02:54 AM
mickey513
Apr 6, 2003 01:10 AM
