Vitara pistons in D16A6. Too Low C/R?
Old Jan 17, 2005 | 12:12 AM
W O T's Avatar
Default Vitara pistons in D16A6. Too Low C/R?
Just read 17 pages on the Vitara thread, doesnt seem lik anyone has tried them in a D16a6 motor.
Ive got a D16a6, head is milled .040 and I can go with a 2 layer headgasket if need be
Ive got a set of SRP's but knowone including me knows the comrpession of them and I dont wanna drop in 11:1 pistons, run 17psi on 93 octane and BOOM!
And my block is already honed for stock 75mm and would save machine shop money and I could sell the SRP's
I plan running them in @ 16-18psi on a t3 .60/.63 daily
Thanks for any imput
Old Jan 17, 2005 | 05:53 AM
nonvtecD's Avatar
.030 milled on a head is usually a point of compression, that should be enough so the vitaras won't be a problem. You have forged rods for this motor?
Old Jan 17, 2005 | 09:38 AM
W O T's Avatar
Default Re: (D15B7turbo)
Ive got used eagle H beams with ARP 2000 rod bolts in there. Turned this into a major budget build
And I dunno where I read it but I heard .040 was a point of compression....
But does anyone have a compression ratio for the vitaras in a an A6 block n head
Old Jan 17, 2005 | 10:42 AM
W O T's Avatar
Default Re: (W O T)
well I just bought a set
Wouldnt mind knowing the exact or very close compression
Old Jan 17, 2005 | 10:00 PM
W O T's Avatar
Default Re: (W O T)
Old Jan 17, 2005 | 10:49 PM
xci_ed6's Avatar
Default Re: (W O T)
i believe around 7.8:1 with an unmilled head. i will probably be running that because of the shitty gas i get around here
Old Jan 17, 2005 | 11:18 PM
W O T's Avatar
Default Re: (krustindumm)
hmmm,
and my head is milled .040 and Im probably gonna go with a 2 layer y8 head gasket
think I can get the desired 9:1 compression or even higher..?
Old Jan 18, 2005 | 05:20 AM
nonvtecD's Avatar
Why is 9:1 desired, nothing wrong with 8.5, which is around what you're going to have.
Old Jan 18, 2005 | 10:08 AM
W O T's Avatar
I was actually shooting for 10:1 before I found out I was scammed and given the wrong pistons
Jsut looking for an accurate compression in an A6 unmilled with a stock gasket
Is 7.8:1 correct or is it even lower?
Old Jan 19, 2005 | 10:10 AM
W O T's Avatar
Default Re: (W O T)
Old Jan 19, 2005 | 11:36 AM
racinskittle's Avatar
Default Re: (W O T)
who cares. Boost it and forget it It comes out to about 155psi across each cylinder, we know that for sure. Johnnyquest is using these right now on 10psi.
Old Jan 19, 2005 | 11:46 AM
b16sedan's Avatar
Default Re: (racinskittle)
Why do you want high compression.
Old Jan 19, 2005 | 02:39 PM
Default Re: (b16coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16coupe &raquo;</TD></TR><TR><TD CLASS="quote">Why do you want high compression.</TD></TR></TABLE>
It's the cool thing to do.
OT: Hell, compression's not the only factor in power. Proper turbo selection is too. Just a helpful thought
Old Jan 19, 2005 | 10:11 PM
W O T's Avatar
I dont want high compression, I want a useable powerband
I read that in a stock A6 they give a 7.8:1 ratio, obviously ***** low
But like I said my head is milled .040 and Im gonna run a small headgasket.
THe goal I want is atleast 9.3-9.7:1
Im running a T3 .60/.63, fairly big for a sohc but not a huge dyno fairy
I am also limited to 93 octane and the goal with the car is an 11 second slip
I dont care if it blows on the first run, as long as the slip says 11.XX @ 125+ Ill be a happy mother ******
Old Jan 19, 2005 | 11:19 PM
Default Re: (W O T)
1. There's no way you're going to trap 125 on vitara's.
2. 155psi across is NOT too low either.
3. turbodd16y7vtec just made 250whp @ 10psi with 155psi across the board. Stock block.
I like that 60 trim .60/.63 turbo
Old Jan 19, 2005 | 11:39 PM
W O T's Avatar
1.You havent seen my motor build
2.Slicks,LSD,equal length mani, fat turbo, 18psi, completely worked head = 300whp
Sooooooooooo much done to this motor for under $3000 including the turbo kit its not even funny
Ive also got N20 and lot of axles if I feel like it lol
Old Jan 19, 2005 | 11:48 PM
Default Re: (W O T)
Im sure you could run 11's and im sure the setupd kicks ***. Hell im not even doubting 300whp.
GL with the setup! Hopefully everything goes well.
Old Jan 20, 2005 | 12:07 AM
W O T's Avatar
hopefully is the exact word, everything ***** up for me
I was doing some sliding around in **** tonight in a parking lot with some friends, got a little to fast and a little to sideways and couldnt correct myself, right up onto and over the curb with the car resting on the sideskirts..... my sideskirts were moulded......
Ya that ***** now held on by a screw and some black duct tape (my cars black lol)
Time to get rid of the body kit anyways, dont want my baby to get ripped off
BTW- sliding on ice is kickass
Bump for an accurate compression ratio
Old Jan 20, 2005 | 05:17 AM
nonvtecD's Avatar
Get a RWD, then you can launch at the track and slide around in the dry ;^), your compression is going to be right around 9:1. Just put them in, you'll be fine.
Old Jan 20, 2005 | 10:02 AM
W O T's Avatar
coolio
Old Jan 24, 2005 | 05:25 PM
G3NR8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racinskittle &raquo;</TD></TR><TR><TD CLASS="quote">
Finally some #'s for the vitaras. My motor is torn down and being rebuilt right now....couple more months till its in, but its good to hear some decent #'s to look forward to!
Old Jan 24, 2005 | 05:38 PM
Default Re: (G3NR8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G3NR8 &raquo;</TD></TR><TR><TD CLASS="quote">Finally some #'s for the vitaras. My motor is torn down and being rebuilt right now....couple more months till its in, but its good to hear some decent #'s to look forward to!</TD></TR></TABLE>
That was actually on a stock block ~8.5 compression
Old Jan 25, 2005 | 12:02 AM
W O T's Avatar
11's are a must with my setup
Old Jan 25, 2005 | 02:25 AM
W O T's Avatar
Default Re: (W O T)
Just paid for an LSD
NEED COMPRESSION!
Old Jan 25, 2005 | 02:44 AM
fjt's Avatar
fjt
Default Re: (G3NR8)
Those are not the only numbers..
Currently i have 2 friends with Civic Coupes running 12's with the vitaras..
1- D16Y7 motor on a 1998 Coupe.. Log Manifold, Small t3(.48/.42), starion FMIC,Stock head and valve train, running on a SAFC,walbro Fuel pump and some DSM injectors--&gt; Best time on slicks so far is 12.26@112mph. Car is complete and with A/C hooked up and cooling
2-1999 civic HX(D16y5)..Basically Same setup as above. Running 12.7@107mph
I expect to run 12's too on a SOHC non Vtec with my setup..just havent had time to finish this damn thing.. New Clutch,Flywheel and LSD going in soon so i can tune and go search the 12 sec runs..
