Moving actual clutch engaugment?
Old Jan 16, 2005 | 11:10 PM
B-B-K's Avatar
Default Moving actual clutch engaugment?
I have a 91 CRX si with a JDM B16 S1 tranny with an Exedy stage one clutch. My question is this, my clutch engauges about an inch or an inch and a half off the floor....is there any way to get the clutch to engauge a lil higher so I will have more time to shift?
I have the release bearing as close to the pressure plate as I can get it with out it riding. I feel a lil play in the lever and I can hear it hittin the pressure plate if I move the lever by hand.
Isnt the closer the release bearing is to the pressure plate the higher the engaugment?
Any of this make sense? Any ideas?
Thanks
Matt
Old Jan 16, 2005 | 11:48 PM
Rywire's Avatar
Default Re: Moving actual clutch engaugment? (B-B-K)
Try and get 1/8 of an inch of play in the lever if possible.
Old Jan 17, 2005 | 09:56 AM
B-B-K's Avatar
Default Re: Moving actual clutch engaugment? (droppedcrxsi)
So basically get the throw out bearing as close to the pressure plate as I can? Thats the only way to bring the actual engaugment as far out?
Old Jan 17, 2005 | 12:01 PM
mahatma's Avatar
Hopefully this is relevant, as it pertains to a ZC w/Si tranny.......
I was able to adjust the point at which the clutch engages by turning a **** on the clutch cable. The **** was very close to the transmission, easily accessible by opening the hood. Easy like Sunday morning.
Since you're trying to raise the engagement point, turn it whichever way is easiest (can't remember). I was trying to do the opposite of you--lower the point--and I remember it took some elbow grease to tighten it up.
Old Jan 17, 2005 | 12:13 PM
kid-honda's Avatar
Default Re: Moving actual clutch engaugment? (mahatma)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mahatma &raquo;</TD></TR><TR><TD CLASS="quote">I was able to adjust the point at which the clutch engages by turning a **** on the clutch cable. The **** was very close to the transmission, easily accessible by opening the hood. Easy like Sunday morning.
.</TD></TR></TABLE>
Old Jan 17, 2005 | 12:18 PM
itsallmotor's Avatar
From: rigged and ready., WashingtonD.C./FlagstaffAZ/TempeAZ usa
Default Re: Moving actual clutch engaugment? (kid-honda)
why dont you just adjust the nuts that hold the clutch cable near the tranny
turbosivtec
Feb 8, 2009 02:26 PM
Lil_Wyte
Sep 20, 2008 02:27 PM
B-B-K
Feb 9, 2005 09:25 PM
Accord15
Oct 23, 2002 01:24 PM
