Integra Throttle and Clutch cable Really needed for B16 swap
Do you really need to use the throttle & clutch clabe.
or is there some mod you can do when doing a b16 swap?
my B16 came with a piece of cable cut on the braket where you mount the cable on the manifoild. ? i need to know so i can order parts because i want to finish the swap this week.
To use the stock throttle cable you will need to mod the mounting bracket, I just used a integra one cause I wanted a new tight cable(it felt alot better)
But I did use my stock clutch cable as well as every other person I have done it for or helped do it.
I USED A 90-93 INTEGRA CABLE FOR THE THROTTLE AND IT WAS TO LONG SO I JUST WRAP IT AROUND IT TWICE AND FOR THE CLUTCH CABLE JUST USE A STOCK CRX BUT YOU MITE NEED TO CUT SOME OF THE RUBBER PART. So for the caps locks.
Yup, use a 90-91 teg throttle, or build/buy a custom bracket. To use a crx clutch cable, just trim off the excess on the rubber boot.
Ryan
Ryan
on my friends b16, eg we just used the stock cable, modded the stock bracket, it took a while, but it works
What do i have to do to the clucth cable to make it work.
It seems like it is just too short does anyone have detailed instructions to make it work its a 90 DX
im using a 91 civic si clutch cable with a 90 tegra clutch cable braket..the instalation is tight. but it fits perfect.might have to force the end of the cable into the braket. n yeah................ 90 speedo cable n clutch cable are a must swap for a b16 swap
crxsleeper210
Jul 17, 2008 10:07 PM
4gencivicef9
Apr 9, 2006 07:18 PM
