Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Numbering for VIR Speedtrial event
Old Jan 10, 2002 | 10:34 PM
GRM Scott's Avatar
25 Year Member
Default Numbering for VIR Speedtrial event
This was mentioned in another thread, just wanted to see if we could get clarification...is there numbering by group skill? And will relatively large magnets hang on at track speeds? I'd imagine they would, but i haven't had my magnets above 80ish. Thanks!
Old Jan 10, 2002 | 10:38 PM
getfast's Avatar
Default Re: Numbering for VIR Speedtrial event (Aleph)
0-99 for staff/workers,
100-199 for Beginners,
200-299 for Intermediates,
300-399 for Advanced drivers,
400-499 for Instructors
Relatively large magnets should hang on, but that is based on surface area and thickness. I know of people who have lost 8-10" tall, thick autoX magnets at 120+ mph on the straights at VIR, but others say they do just fine. Best way to fixit is to put some scotch-tape on the frontmost edges...
Hope that helps,
Jon
SpeedtrialUSA east coast director
804.355.1010 w / 804.938.TIRE c
Old Jan 11, 2002 | 03:27 AM
Brett@SoloRacer.com's Avatar
Aleph, just an FYI, I had my number magnets (about 12"x12") on at Nelson Ledges the few times I went. They stayed on just fine. I wouldnt count on small magnets staying put though.
Old Jan 11, 2002 | 03:52 AM
Grumpy's Avatar
New User
Default Re: Numbering for VIR Speedtrial event (SoloRacer.com)
A flying magnetic number at 120MPH could be quite dangerous. Some tracks and sanctioning bodies prohibit them for this reason.
Grumpy
Old Jan 11, 2002 | 04:21 AM
urbanlegend21's Avatar
New User
Default Re: Numbering for VIR Speedtrial event (Grumpy)
We will also put your numbers on the windows with shoe polish during tech, I promise I will put them on pretty so it looks good
Old Jan 11, 2002 | 05:25 AM
ceas's Avatar
Default Re: Numbering for VIR Speedtrial event (George Knighton)
If your car is anything close to white - this will work for you.. Wax the area pretty good, and then draw on your car with a dry-erase marker.. I do it all the time on my car (not just for track numbers) and it usually comes right off. If it gets stubbern, just put some elbow grease into it..
ceas..
Old Jan 11, 2002 | 06:05 AM
Lees Z's Avatar
New User
Default Re: Numbering for VIR Speedtrial event (ceas)
I don't know if the dry erase could ever stain the finish. I'm not sure I would want to risk that. I do know that I've used duck tape and electrical tape over a waxed/polished area and only had to use a little Citrus type cleaner to get off the most stubborn glue. It didn't hurt the finish at all.
I
Old Jan 11, 2002 | 06:11 AM
phat-S's Avatar
Default Re: Numbering for VIR Speedtrial event (Lees Z)
I use circle magnets (10" x 10") and they have never budged even in a downpour at VIR - then again the car only hits 124mph sooooo, what do I know. The number magnets are the ones I always see flying off of Shultz' car so I'd say they are suspect
Also, shoe polish ain't the most desirable medium in the rain IMHO.
Old Jan 11, 2002 | 06:12 AM
New User
Default Re: Numbering for VIR Speedtrial event (phat-S)
or you can be like me and just not wash the numbers off from the last event
Old Jan 11, 2002 | 06:14 AM
Back in Black's Avatar
Rather OG
Jason (Darth Vade R) had some nice numbers that stayed on perfectly well on both straights at VIR...which means about 130 since he was in an ITR.
I should clarify. Actually, I decided to go with stick on instead after speaking with Jon about the matter. As far as appearance goes, here's a pic of my R with the numbers.
The magnets look IDENTICAL to the stick on, and appear to be very high quality. David (FAST4DR on the board) is purchasing a set of magnets from me that I had planned on using before deciding on the stick on. He'll be running them at the Speedtrial event should you like to take a closer look...
Jason- who hopes this helps
Old Jan 11, 2002 | 06:26 AM
phat-S's Avatar
Default Re: Numbering for VIR Speedtrial event (Darth VadeR)
Not to be an ***, but those are the type of magnetic numbers I see spiraling toward earth entering T1 at VIR and CMP. I would suggest to the purchaser to tape down the leading edge.
Old Jan 11, 2002 | 06:29 AM
Rather OG
Why would you call yourself an *** for stating that precaution? That's good advice...
Jason- who, IF HE HAD MAGNETS, would tape the corners...
Old Jan 11, 2002 | 06:54 AM
TarheelFan's Avatar
What is the cost of a set of stick on numbers like Jason's? What about the magnetic ones? Are the stick ons removable/reusable?
Also, how do you know you've got a unique number for an event, or do they even care about dups?
Old Jan 11, 2002 | 07:15 AM
4doorH22's Avatar
I hope this is a slight exaggeration? I think Warren can [i]maybe[i/] hit 130 in his R at VIR?
Old Jan 11, 2002 | 07:30 AM
phat-S's Avatar
Default Re: Numbering for VIR Speedtrial event (TarheelFan)
Just thought I'd err on the side of caution - been kinda contentious around these parts as of late
You can always pick something rather unique and you should keep it. For NASA, you can check/confirm with Elyse (LeesZ ?). With Speedtrial, it shouldn't matter as they put on your numbers in a cold dank parking lot - make sure Morgan does it- others tend to leave drips and runs (no names of-course) - maybe that's because I tagged a Tahoe while lining up for tech though . You can also get an extra "1" or something to make a "4" into a "14" if needed. And yes, they do care about dups - its how the corner workers communicate information about you on track.
[Modified by phat-S, 11:33 AM 1/11/2002]
Old Jan 11, 2002 | 07:52 AM
New User
thanks Adam
usually the only non-seqeuntial numbers we allowed at Speedtrial are permanent numbers on the side of built race cars that do not have a clearly visible window surface to write numbers on
after listening in on several sessions of VIR over the track worker radio, the corner workers will use everything possible to describe the car they want for you to look at or warn you about, numbers help distinguish even more but are also used, in Speedtrials case, for class recognition and logging information
[Modified by urbanlegend21, 4:53 PM 1/11/2002]
Brian*'s Avatar
Default Re: Numbering for VIR Speedtrial event (4doorH22)
I dunno Dave, Warren was pretty far into 5th when I was riding with him . And if your shoe polish numbers start to fade, people like me come along and refresh em on the grid for ya, its like a full service car wash, except you have to clean the polish off, not us
Brian
Old Jan 11, 2002 | 08:44 AM
getfast's Avatar
Default Re: Numbering for VIR Speedtrial event (Lemon Drop)
The main thing that screws with white shoe polish's ability to stick to windows is, believe it or not, Rain-X.
On non-Rain-X'd windows, once white shoe polish dries thoroughly (and assuming it is applied in the dry)... it will stay on for literally *months*.
On Rain-X'd windows, it will never go on correctly because it keeps beading up, and it won't stick nearly as well in any kind of condition.
Long story short? Print numbers on a sheet of paper and tape them to the side of the car instead.
Jon
whose SE-R has been #01 since 12/7/01 thanks to white shoe polish and no Rain-X
Old Jan 11, 2002 | 09:07 AM
GRM Scott's Avatar
25 Year Member
Default Re: Numbering for VIR Speedtrial event (JonSE-R)
I think i'll rely on the shoe polish method, I don't really have an easy way of creating numbers in the 2XX range with my magnets, and loosing them at speed would suck in a variety of ways anyway Thanks for all the answers!
Old Jan 11, 2002 | 09:33 AM
New User
i promise to make them very nice looking
Old Jan 11, 2002 | 09:55 AM
phat-S's Avatar
Default Re: Numbering for VIR Speedtrial event (urbanlegend21)
The man's got mad skillz y0!
Old Jan 11, 2002 | 10:31 AM
smokin rubber's Avatar
Does that mean PY shoe polish?
Old Jan 11, 2002 | 10:57 AM
New User
Default Re: Numbering for VIR Speedtrial event (smokin rubber)
nope MSY polish!
Old Jan 11, 2002 | 11:50 AM
xjohnx's Avatar
Jon
heh...mine's been 113 since then as well...haven't had the time to get a razorblade out to get the damn things off, porbably should do that fairly soon
Old Jan 11, 2002 | 11:57 AM
Honda318dx's Avatar
Jon
I still have 02 and SLOW! written on the back of mine, thanks to Bryan..
