Spoon Cat Jack ( what's inside?)
Old Jan 10, 2002 | 10:22 PM
itr501's Avatar
Default Spoon Cat Jack ( what's inside?)
is the spoon cat jack a 2.5 testpipe with a wider diameter metal jacket? Or is it hollow inside with a flared out body? I hope I'm wording things right here.
Old Jan 10, 2002 | 10:24 PM
Mike M's Avatar
Founding Member
Default Re: Spoon Cat Jack (itr501)
The piping is wider, Nothing inside there
Old Jan 10, 2002 | 10:28 PM
itr501's Avatar
Default Re: Spoon Cat Jack (TypeRmsm)
Any reason why they make it wider?
Old Jan 10, 2002 | 10:47 PM
Mike M's Avatar
Founding Member
Not sure
Old Jan 10, 2002 | 11:25 PM
EPGONZALEZ's Avatar
the chamber is supposed to cancel out sound waves or some b.s. like that...it might actually work though...when i switched from my car sound cat to the spoon cat jack there was no real raise in noise level..but i did gain a few ponies..
i like it becuase it tapers to 2.25 for my jaydeehem exhaust
[Modified by EPGONZALEZ, 8:27 AM 1/11/2002]
Old Jan 10, 2002 | 11:37 PM
mafay2's Avatar
New User
Default Re: Spoon Cat Jack (EPGONZALEZ)
I think it will somehow make it quieter due to some sound wave or some **** like that!! Can some engineer that know something about how sound wave work come in a explain??
Old Jan 10, 2002 | 11:53 PM
itr501's Avatar
Default Re: Spoon Cat Jack (mafay2)
The best I came up with is a slight increase in back pressure sinze the gas might accumulate more inside the chamber?
Old Jan 10, 2002 | 11:54 PM
Reid's Avatar
Global Moderator
Seems like a case of sound waves hitting each other and cancelling each other out.
Old Jan 11, 2002 | 05:03 AM
Johnny Tran's Avatar
Default Re: Spoon Cat Jack (Reid)
im an engineer, and im telling you it wont work
as far as sound cancellation is concerned, there is no way to "deaden" the sound pulses.
[Modified by Blue-POS, 6:05 AM 1/11/2002]
Old Jan 12, 2002 | 02:08 PM
ITR#132's Avatar
Sound wave?? The Spoon Cat Jack is the same shape as the Japanese Catalytic converter. You can have a Spoon Cat Jack by hollowing out the factory JDM cat. At least, that is what I have seen when I compared both of them. Only difference was that the factory cat can accept heat shields.
Old Jan 12, 2002 | 02:39 PM
xtrafastcivic's Avatar
Default Re: Spoon Cat Jack (ITR#132)
how about the tapered design. a little back pressure for the free flowing exhaust(spoon N1)??
calvinx29
Jan 31, 2006 03:29 PM
Mario
Jun 10, 2004 02:59 PM
2000 Integra R #760
Oct 29, 2002 03:51 PM
onyx00
Mar 5, 2002 03:19 PM
JDM_Type-R
Feb 1, 2002 12:28 AM
