CRX Underdrive Crank Pulley! Need a lil' help
Old Jan 16, 2005 | 03:08 PM
z6CRXSi's Avatar
Default CRX Underdrive Crank Pulley! Need a lil' help
I recently bought a zc block to replace my a6 block since it has a 2in hole near the exhaust manifold from a rod! I got the ZC full short block home and noticed it had a lightweight Underdrive pulley on the crank. I would like to keep the u/d pulley but I am not sure what belts i should use will stock work? If not does anyone know any that will? Does the pulley do much as far as performance?
thanks
looks like this
Old Jan 16, 2005 | 03:38 PM
xci_ed6's Avatar
Default Re: CRX Underdrive Crank Pulley! Need a lil' help (z6CRXSi)
try the stock belts, if they dont work, wrap a string around the pully's to measure the length of the belt you will need. Take the old belt and the measurement to a parts store, they can help you out.
Old Jan 16, 2005 | 03:42 PM
eumoria's Avatar
are you going to try and mate an A6 head onto a ZC block? Because if you are you're going to be unhappy.
Old Jan 16, 2005 | 05:43 PM
z6CRXSi's Avatar
Default Re: CRX Underdrive Crank Pulley! Need a lil' help (eumoria)
Im going with a z6 head with apexi vafc. Maybe DOHC ZC pistons (pm7?) and PG7 ECU. Not sure how the ECU would work with z6 head and apex'i vafc.
Old Jan 17, 2005 | 04:01 PM
xci_ed6's Avatar
it will all work out nicely if it is a SOHC ZC. But i think your compression might be a little bit too high with the ZC pistons & Z6 head. Not exatly sure though, i was calculating mine for a Y8 head and ended up at well over 12:1 static.
Foxcow
Jul 7, 2021 11:39 AM
d15maverick
11
Feb 13, 2005 08:00 AM
StupidSlowRSX
May 5, 2004 06:58 PM
gregv
Feb 16, 2004 08:03 PM
VTgringo
11
Aug 2, 2003 09:07 AM
