Accord turbo manifold
Old Jan 16, 2005 | 10:00 AM
type-t's Avatar
Default Accord turbo manifold
hi guys,
i've searched for the website that sells the unwelded piping to make your own
turbo exhaust manifold. Can someone help me please. Also is there any way to
the a/c when adding turbo to a 92' accord? thanks
Old Jan 16, 2005 | 11:43 AM
quick gixxer's Avatar
Default Re: Accord turbo manifold (type-t)
got it for ya right here...... http://www.jgstools.com/turbo/index2.html
Also if you try http://www.homemadeturbo.com there is a guy called "weirracing" that makes exhaust manifold flanges for $33.00
Old Jan 16, 2005 | 02:49 PM
iam7head's Avatar
Default Re: Accord turbo manifold (quick gixxer)
almost all the crappy log style manifold will clear the ac and PS line
but it will take some skilled to tig weld you a equal-length header style mani
Old Jan 23, 2005 | 04:52 PM
type-t's Avatar
Default Re: Accord turbo manifold (iam7head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">almost all the crappy log style manifold will clear the ac and PS line
but it will take some skilled to tig weld you a equal-length header style mani</TD></TR></TABLE>
you're talking about the manifolds that dont drop down to the a/c level right?...what is the loss in performance when ever you use this type of manifold versus the crazy looking huge manis?
Old Jan 23, 2005 | 04:58 PM
fw190bvi's Avatar
the problem w/ cast maniforlds that let you use ps, ac, or w/e ("smaller style") is that the wastegate can at most, "draw" air from 2 of the runners, thusly, only two of the chambers....they also arent equal length, like those "crazy looking huge manis", which means not all the exhaust gas is entering the hot side at the same velocity and what not....i have no experience with log style custom manifolds, but i assume when it just comes to street performance, the cost outweighs the benifits....but once again, you might wanna talk to someone w/ direct experience on both styles
Old Jan 27, 2005 | 06:37 PM
type-t's Avatar
Default Re: Accord turbo manifold (fw190bvi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi &raquo;</TD></TR><TR><TD CLASS="quote">the problem w/ cast maniforlds that let you use ps, ac, or w/e ("smaller style") is that the wastegate can at most, "draw" air from 2 of the runners, thusly, only two of the chambers....they also arent equal length, like those "crazy looking huge manis", which means not all the exhaust gas is entering the hot side at the same velocity and what not....i have no experience with log style custom manifolds, but i assume when it just comes to street performance, the cost outweighs the benifits....but once again, you might wanna talk to someone w/ direct experience on both styles</TD></TR></TABLE>
can anyone help complete the answer? thanks
blue2000em1
Jul 9, 2007 07:57 PM
SQ is the SQUAD
Jan 8, 2006 02:53 PM
NonVtecSOHC97
Welding / Fabrication
20
Nov 15, 2004 10:22 PM
Phat8186
Oct 31, 2004 03:27 PM
THE_-_MAN
Jan 4, 2002 07:55 PM
