wiring questions never seen this posted before
Old Jan 16, 2005 | 08:09 AM
91crx but i heard vtec's Avatar
Default wiring questions never seen this posted before
ok guys instead of going dx to si waht about going dx to odb1 is it hard to do if i already have a conversion harness and distributer and injectors thanks for any help
Old Jan 16, 2005 | 08:14 AM
-16V-'s Avatar
Default Re: wiring questions never seen this posted before (91crx but i heard vtec)
Nothing has never been posted.
But if u search around theres tons of that stuff around here.
Old Jan 16, 2005 | 08:22 AM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91crx but i heard vtec &raquo;</TD></TR><TR><TD CLASS="quote">ok guys instead of going dx to si waht about going dx to odb1 is it hard to do if i already have a conversion harness and distributer and injectors thanks for any help</TD></TR></TABLE>
A DX to Si swap is a DPFI to MPFI swap. a "DX to OBD1 swap" is still pretty much the same thing, you're just now adding an extra step. You're doing a DPFI swap then doing an OBD 0 to OBD 1 conversion. I'll let somebody else give you the specifics on exactly what parts you'de have to swap out.
But ask yourself this:
#1 what will be gained by doing a DPFI to MPFI swap?
then ask yourself this:
#2 once I am MPFI what will be gained by going with OBD 1?
Default Re: wiring questions never seen this posted before (-16V-)
well first off i want to put a b16a in the car and i just dont want to stay obd0 anymore i have had alot of crxs obd0 want something different
Old Jan 16, 2005 | 08:30 AM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91crx but i heard vtec &raquo;</TD></TR><TR><TD CLASS="quote">well first off i want to put a b16a in the car and i just dont want to stay obd0 anymore i have had alot of crxs obd0 want something different</TD></TR></TABLE>
If that's the case, then I say go for it. If you swapping in a B16 with OBD 1 stuff, the swap is a lot easier (IMO). IIRC, with a DX to B16 OBD swap you have to wire in resistors for your injectors but other then that I dot know what else.
With an OBD 1 B16a, as long as you get a custom engine harness, and a OBD 0 to OBD 1 ECU conversion harness, the install will be a snap. Nikitad made me an engine harness and OBD conversion harness that I just had to plug it in. The same thing can be done on your setup. As long as the correct wiring changes are made it will be easy, and you can concentrate on other parts of the swap.
JJ's civic
Jul 7, 2007 12:31 PM
95 vtec
Honda Civic (2006 - 2015)
18
Nov 11, 2006 07:28 AM
ZEXnREX91Si
Jul 9, 2005 05:57 PM
Bad89rex
Apr 22, 2005 06:09 PM
2ndGenREX
Jun 5, 2003 07:37 AM
