dx or si tranny
my si transmission is about to take a **** as its making quite a bit of noise in high rpms, so i have this dx transmission in my backyard. Should i just go ahead and swap it ? i mean i want power and all, but since the dx is sitting there, i might as well right? or should i get a job and save for another si transmission. I still want decent power tho .
my question is , how much whould it effect my time in the 1/4th mile?
if i remember correctly the dx and si tranny are the same except for the final drive
just get a si one and you be good
Modified by komat at 9:40 AM 1/16/2005
but mabe its the final drive thats messed up, cause like i get this wierd whinning sound at high rpms in every gear. should i replace the tranny oil with a more thicker oil?
try some 0w30 mobil1 synthetic, sounds like one of your bearings in the tranny going bad, or it's just dry, have you checked the oil, you should be able to use the bearings out of the dx tranny. If you have tried the oil thing and that did not work, replace that tranny quick. Otherwise it is going to scatter.
lshatch1.8
24
Jan 19, 2006 09:39 PM
