First time fiberglass
Whatever you deside to make, always make a template out of something first. Like carboard or something.
Get the hair and lay it on the template. Next get a brush and mix the resin and then apply it over the hair. When your done you should be able to remove the template and have your object there. There will be some sanding needed to be done and then paint. Good luck, always wear a mask and gloves.
goto http://www.fibreglast.com and go into there forum and join... its great for learning a lot about carbon fiber and fibeglass.
4-ageTOg63
Honda Motorcycles
Jul 15, 2005 05:47 PM
