fitment on 98 GSR exhaust to 98 LS exhaust
Old Jan 15, 2005 | 05:38 PM
xiLLtegRax's Avatar
Default fitment on 98 GSR exhaust to 98 LS exhaust
its a simple question. i know that obd1 gsr exhaust would not fit on 98 LS. but does 98 integra GSR exhaust fit perfect on 98 integra LS? some people told me it might not fit because of the length of cat. how about if you change the header and the exhaust would it fit with the stock LS cat?
Old Jan 15, 2005 | 06:28 PM
tub_sephiroth's Avatar
Default Re: fitment on 98 GSR exhaust to 98 LS exhaust (xiLLtegRax)
NO! 00-01 GSR will fit perfect on the LS.
Old Jan 17, 2005 | 06:28 PM
xiLLtegRax's Avatar
Default Re: fitment on 98 GSR exhaust to 98 LS exhaust (tub_sephiroth)
whats if i get the headers to cat, and cat to exhaust. will it fit?
Old Jan 17, 2005 | 06:32 PM
dFreezy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xiLLtegRax &raquo;</TD></TR><TR><TD CLASS="quote">whats if i get the headers to cat, and cat to exhaust. will it fit?</TD></TR></TABLE>the cat accounts for about 3-4 inches of that difference right there. the 94-99 gsr cats are around 13" while the 00-01 gsr's and 94-01 LS/GS/RS have longer 17" cats. if you want things to fit properly, you will have to get the entire exhaust system including the cat.
Old Jan 17, 2005 | 07:00 PM
xiLLtegRax's Avatar
Default Re: fitment on 98 GSR exhaust to 98 LS exhaust (dFreezy)
so basically if i get the header, cat, and catback everything will be fine right? someones giving me a good deal on headers and exhaust off of i think 98 gsr. i kinda knew it didnt fit so i just wanted to make sure. i guess im gonna start looking for a cat for gsr
Old Jan 17, 2005 | 07:07 PM
You_Get_Vapors
Guest
Posts: n/a
I think you only need to switch out the A-pipe to run the GSR exhaust, but i dont know if the 4-2 ports match or where it would place the cat.
I looked up both cars and it had the same diagram for both cars with 3 different A-pipes. They part numbers for the cat were different but I think thats only to match it with the chassis. Otherwise the actual part is the same.
If I'm incorrect about the cat excuse me but It looks like only the A-pipe is different.
Old Jan 17, 2005 | 07:10 PM
dFreezy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xiLLtegRax &raquo;</TD></TR><TR><TD CLASS="quote">so basically if i get the header, cat, and catback everything will be fine right? </TD></TR></TABLE>yup, that's correct.
Rcp
Dec 7, 2005 01:28 PM
2lowintegra
Feb 6, 2003 02:33 PM
B00ST2nR
Dec 13, 2002 10:51 AM
LOwrestling2001
Mar 14, 2002 09:43 AM
StinkyTofu
Nov 30, 2001 02:07 PM
