90 integra wont start...could it be my ECU???
Old Jan 15, 2005 | 03:47 PM
tirref22's Avatar
Default 90 integra wont start...could it be my ECU???
hello all. i've been having this intermittent problem where the car will choke and lose fuel/power, while driving, for a sec or two. and occassionally, it will not start in the morning before work, for about 10 mins. today, i tried to start it all day. it cranks, but doesnt fully start. it turned over once about an hour ago, only to sputter then run fine for about 15 secs, then lose power and wouldnt start again. i've replaced the battery, spark plugs, fuel filter, cleaned injectors, new distributor, rotor, etc. the "check engine" light is still not on, as it hasnt been since this problem began....could my computer (ECU) be bad? i'm out of ideas.
Old Jan 15, 2005 | 04:31 PM
93tegy's Avatar
Default Re: 90 integra wont start...could it be my ECU??? (tirref22)
My 93 did somthing similar it ended up being the ignitor.Not to pricey but you might want to check with a mech.
Old Jan 15, 2005 | 06:19 PM
LSBOI's Avatar
you may want to checkhttp://www.g2ic.com and do a search they have great info
93daintegra
Sep 30, 2008 04:58 PM
silverbur
Feb 5, 2008 01:42 PM
bboy_mikey
May 20, 2007 05:56 PM
prophetjinn
Apr 28, 2006 12:24 AM
si00000
Nov 1, 2001 06:10 PM
