Bolt size to remove rear drums
Old Jan 15, 2005 | 02:20 PM
88 rex's Avatar
Default Bolt size to remove rear drums
Does anyone know the exact size to remove the rear drums? I have found conflicting sizes. Some have said 10mm and some others have said 12mmx1.25?
Thanks
Old Jan 15, 2005 | 02:59 PM
NCRXSi's Avatar
Default Re: Bolt size to remove rear drums (88 rex)
Are you asking about the nut that holds the entire rear drum assembly on? Because to just remove the drum, you just remove the wheel, there are no nuts or bolts that hold the drum cover on.
Old Jan 15, 2005 | 05:38 PM
xci_ed6's Avatar
Default Re: Bolt size to remove rear drums (NCRXSi)
i think the thread size is 8mmx1mm
it is a standard sized bolt, just grab some from off the car till you find one that fits, then measure the threads.
Old Jan 16, 2005 | 03:29 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NCRXSi &raquo;</TD></TR><TR><TD CLASS="quote">Are you asking about the nut that holds the entire rear drum assembly on? Because to just remove the drum, you just remove the wheel, there are no nuts or bolts that hold the drum cover on. </TD></TR></TABLE>
There are threaded holes in the drum you can use
as a pulling mechanism by threading a bolt into them..
The size of the bolts is 8mm x 1.25mm pitch..
Any of bolts on the car with a 12mm head on it should work..
trecool44
May 22, 2009 09:42 AM
kidcool1977
Dec 9, 2008 12:34 AM
the-one1
Jul 19, 2003 02:50 PM
kappa
Mar 19, 2003 10:25 PM
