bought brand new projectors and ......(prob)
well i bought new projectors not the one piece the 2 piece ones the one wth the corners so i plug the 2 plugs in and they dont work but mean while i put the stock ones back in and it worked so some how the projectors isnt gettting juice help plz
Modified by crableg03 at 3:21 AM 1/17/2005
Modified by crableg03 at 3:22 AM 1/17/2005
Modified by crableg03 at 3:37 AM 1/17/2005
im using the bulbs that came with them but what i notice is its not like the stock bulbs it looks like the corner bulbls but a little bigger..
well heres pics
hers one of the plug and buld but what i dotn get is the bulb is differnt than stock bubls cause i bout the hyper white one thinkin they whoud fit but they dont ....
well . the stock bulb and the projector bulb are entirely different bulbs, as you can already see that yourself, so the stock bulbs will not fit in the projector . but i am guessing that it is probably something wrong with your projector bulb or that you are not getting a connection somewhere between the bulb and the socket . make sure the projector bulb is connected and making contact where that clear rubber covering is at and i think that you need to make sure that the paper clip looking thing is clamped down on the projector bulb when it is installed . hope that helps you out .
hey, i got projectors in my ride too, and sometimes the connection is faulty. it might just be the wiring. All i do is mess with the wires a little(the wires that connect into the back of the housing). hopefully this helps. good luck
well i found out that the prongs werer to short and wernt making a connection so i made a harness if u wannna call it that with aq make and female type thing and plugged it in and now they work fine
Those projectors have the shittiest output.... I got mine and within a month one of them went out.. i fiddled with it for 3 days before i finally got pissed and hit it with my fist. After i hit it the light flickered on and i realized that the ground was bad.... so i re-did all the power and ground wires and now they work fine with shitty light output. I've been scheming up ways to get a brighter bulb in there or something without retrofitting them... any ideas?
EF-Factory
18
Jan 19, 2008 02:13 PM
JCracer723
Apr 10, 2007 09:42 AM
Unjockable
Feb 21, 2006 05:09 PM
