95 hatch auto to man
Old Jan 15, 2005 | 12:26 PM
dbwsi's Avatar
Default 95 hatch auto to man
Does anybody know of anyone that makes mounts to convert a 95 hatch to a manual transmission?
Old Jan 20, 2005 | 06:03 AM
Electron_LS-Vtec's Avatar
Default Re: 95 hatch auto to man (dbwsi)
place racing and hasports makes the mount to make it happen.... i did it in a DA intrgra with good results....good luck
Old Jan 20, 2005 | 11:25 AM
SkRiBLaH's Avatar
Default Re: 95 hatch auto to man (Electron_LS-Vtec)
http://www.jdmshit.com/hcp/index.html
EG-AT Transmission Mount (For Auto Chassis)
Fits 92-95 Civic, 93-97 Del Sol
thats wwhat i used
Old Jan 20, 2005 | 12:20 PM
SOHFAST94's Avatar
If budget is what you're looking for then use the original mount from the 5-speed.
Old Jan 20, 2005 | 12:26 PM
MONSTERZC's Avatar
Default Re: (SOHFAST94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHFAST94 &raquo;</TD></TR><TR><TD CLASS="quote">If budget is what you're looking for then use the original mount from the 5-speed.</TD></TR></TABLE> how can you use the 5 speed mount when the location of the mount is in a different place than the auto. thats why you need aftermaket one
Old Jan 20, 2005 | 12:47 PM
MrMike's Avatar
Default Re: (MONSTERZC)
yeah if u want your engine to be at a ghetto angle. buy that mount or remove the AT transmount bracket and weld in the MT bracket.
Old Jan 20, 2005 | 03:50 PM
RCautoworks's Avatar
Default Re: (MrMike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrMike &raquo;</TD></TR><TR><TD CLASS="quote">
yeah if u want your engine to be at a ghetto angle. buy that mount or remove the AT transmount bracket and weld in the MT bracket. </TD></TR></TABLE>
Why would it be angled if you use the Honda mounts ment for a manual trans ? And I highly doubt you have to weld anything in because Honda makes all there frames the same to save money. So more then likely the bolt holes are already there and you just need the stock manual mounts.
Old Jan 21, 2005 | 03:54 PM
TeamNextGenChris's Avatar
Default Re: (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">
Why would it be angled if you use the Honda mounts ment for a manual trans ? And I highly doubt you have to weld anything in because Honda makes all there frames the same to save money. So more then likely the bolt holes are already there and you just need the stock manual mounts.</TD></TR></TABLE>
the chassis mount for the upper passenger side mount is in a different spot on auto cars than manual cars.
yuo can either get an adapter mount,or remove the chassis mount and weld it in the manual location.
Chris
Old Jan 21, 2005 | 04:07 PM
Default Re: (TeamNextGenChris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris &raquo;</TD></TR><TR><TD CLASS="quote">
Chris</TD></TR></TABLE>
I see
Old Jan 22, 2005 | 10:14 AM
stockredej1's Avatar
my friend did this on his hatch, drilled out the spot welds on the auto mount, the put the manual mount where the auto one was, lined it up by the welds and the paint color difference, spot welded it in then went all the way around it with a bead. works fine. if you dont want to take that on i would reccomend buying the mount kit. good luck.
a1320honda
Jan 14, 2007 09:46 AM
dbwsi
Jan 18, 2005 08:34 PM
dbwsi
Dec 20, 2004 08:01 AM
Bones Barry
11
May 26, 2004 10:16 PM
Strem
Jul 22, 2003 08:39 PM
