Y8 Manifold question
Sup guys, I posted earlier about the '98 Y8 manifold. My car is an '88 CRX (convereted to MPFI) Hmm, I noticed I have an extra map sensor on the Throttle body and I also have some Sensor on top of the Fuel Rail.
Where are these going to connect to when Im using OBD-1 Electronics?
There is no valve which connects to the Oil Breather? Do I have to tap a hole in the manifold in the same location as the A6/Z6 manifolds?
Also, anyone have wiring diagrams for a Y8 and Z6 Honda Engine heads?
Thanks in Advance,
Jon
Thanks in Advance,
Jon
the sensor on top the the fuel rail is not needed. so you can take the sensor off and put the 2 screws back or you can just leave it there(i know this cause i took mine off). And the map sensor you can use , just unplug your old map sensor and extend the 3 wire plug to reach the new map sensor . hope this helps.
Thanks alot
what about the PCV valve, or the hose that connects to the Oil Breather? There isnt one on the Y8 manifold (But they are on the A6 manifold and Z6 manifold between the 1st and 2nd runners)
4DRmafia
19
Mar 4, 2006 06:11 PM
Kusai.Nihonjin.Desu
Aug 18, 2003 02:25 PM
