accord motor mount question
Old Jan 15, 2005 | 11:19 AM
Drag-Accord's Avatar
Default accord motor mount question
do prelude mounts fit(besides the front motor mount) into a 4th gen accord w/ h22. if so, could i get the ST prothane inserts aswell?? anyone done this??
Old Jan 15, 2005 | 03:59 PM
Default Re: accord motor mount question (93BoostedAcclude)
bump??? come on now, i know you all got h22 swaps
Old Jan 15, 2005 | 04:06 PM
97F22B2's Avatar
I dont think any of the other mounts work other than the front one, but i have heard the drivers side ncan fit with some shaving but that one you cant really do anything to except make a new mount.
Old Jan 15, 2005 | 07:09 PM
Default Re: (97F22B2)
i just said "besides the front motor mount" because i'm going to modify a prelude one. that doesn't fit by itself.
Old Jan 15, 2005 | 09:21 PM
v4lu3s's Avatar
RTFM
why not use hte accord mounts? they fit perfectly fine and you can buy inserts for them.
to use the front lude mount you need to use the front lude crossmember.
Old Jan 16, 2005 | 07:38 PM
Default Re: (v4lu3s)
what is HTE?????
and to use the lude front mount, there are these things called welders lol
Old Jan 17, 2005 | 06:56 AM
v4lu3s's Avatar
RTFM
hte=the
like i said what is worng with using accord mounts? its not as if teh lude ones are stronger or better....
Old Jan 17, 2005 | 11:03 AM
nobody makes aftermarket mounts, or even inserts for the accord mounts. they make an insert for the rear torque mount but that is it.
try launching an accord w/ 500whp and stock accord mounts hahaha you'd get wheel hop so bad you'd brake suspension parts.
looks like my best option is to get the insert for the back mount and fill the rest with urethane as good as i can.
Old Jan 17, 2005 | 11:17 AM
accordselux's Avatar
Me Gusta History
Default Re: (93BoostedAcclude)
http://www.raceperformancepart...9c869
http://www.motionresearch.ca/d...1107G
http://www.upgrademotoring.com...p.htm
Just use an accord mount with any of these three fine products!!
Old Jan 17, 2005 | 11:51 AM
v4lu3s's Avatar
RTFM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93BoostedAcclude &raquo;</TD></TR><TR><TD CLASS="quote">nobody makes aftermarket mounts, or even inserts for the accord mounts. they make an insert for the rear torque mount but that is it.
looks like my best option is to get the insert for the back mount and fill the rest with urethane as good as i can.</TD></TR></TABLE>
prothane and energy suspension make inserts for 90-97 accord for front and rear. if not then 3m window weld works well too to fiull the mounts.
Old Jan 17, 2005 | 12:18 PM
m0t0rhead's Avatar
I have a 97 accord with energy suspension inserts in the front mount.
I've had them in for 3 years. Work well. No hop.
I just recently took them out because the vibration really starting annoying me. Everything in the car rattled and having the A/C on made everything rattle 10x more. Not worth it in my opinion for a car that will only land you a 15 sec time slip if you're a good driver. If you boost on the other hand, it would be worthwhile.
Old Jan 17, 2005 | 01:12 PM
Default Re: (Escobar)
built h22 + boost
thanks for the help guys
too bad hasport wont' make mounts for our cars
Old Jan 17, 2005 | 02:59 PM
Me Gusta History
too bad hasport wont' make mounts for our cars </TD></TR></TABLE>
Thats cause no one wants our cars besides us
Acidcrakker
Nov 27, 2007 10:59 AM
95accordh22a
Nov 22, 2006 04:06 PM
jfish
Oct 9, 2005 07:59 AM
jbonehead85
Jul 18, 2004 09:17 PM
H23preludeSi
Apr 20, 2004 08:17 AM
