any fast h22's still using stock flywheel???
Just curious of what kinda power the stock flywheel will be good up too. 400?? 500?? if i don't have to spend the money to upgrade it, i won't. because having that extra wieght on the flywheel will help off the line.
The flywheel doesn't make any difference. The clutch is what determines how much power you can hold...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93BoostedAcclude »</TD></TR><TR><TD CLASS="quote">Just curious of what kinda power the stock flywheel will be good up too. 400?? 500?? if i don't have to spend the money to upgrade it, i won't. because having that extra wieght on the flywheel will help off the line.</TD></TR></TABLE>
Try stock flywheel turned and balanced works good for me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a »</TD></TR><TR><TD CLASS="quote">500+ on my stock one with 5lbs removed.</TD></TR></TABLE>
I took out 7
I took out 7
integraboosted
Apr 22, 2006 05:50 PM
ProjectLudeSiR
Mar 15, 2004 03:21 AM
