quick turbo question
i have an h22a1. with 119,000 miles on it. the question is . is it worth putting a turbo in it?
and, is it better to put a turbo in a newer car or one that has more mileage and broken in?
A little research would tell you this, but if you run a compression and leak down test, you'll know how healthy the engine is. If it's healthy, you could get away with 6 or so psi before you have to beef up the bottom end: specifically the pistons because H series have weak ringlands and have to be sleeved to run forged pistons.
