f22b vs h23
Old Jan 14, 2005 | 09:46 PM
mrxhe1neken's Avatar
Default f22b vs h23
the h23 and f22b has almost the same specs. but h23's engine is 2.3 and f22b is 2.2. is the 2.3 and the 2.2 much of a diff?
Old Jan 14, 2005 | 09:56 PM
SPEED FoRCE's Avatar
h23 is a dual cam, f is a single cam.
Old Jan 14, 2005 | 10:59 PM
zeroice's Avatar
Default Re: (di3go)
depends if you get the f22b dohc and its pretty much the same as the h23
Old Jan 14, 2005 | 11:12 PM
ZigenBallz's Avatar
Default Re: (di3go)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">h23 is a dual cam, f is a single cam.</TD></TR></TABLE>
sigh...
There's one in every single F22B thread...
Old Jan 14, 2005 | 11:58 PM
accordselux's Avatar
Me Gusta History
Default Re: (ZigenBallz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZigenBallz &raquo;</TD></TR><TR><TD CLASS="quote">
sigh...
There's one in every single F22B thread...</TD></TR></TABLE>
My G22 has a TOHC...Intake, Exhaust, and VTEC!
Old Jan 15, 2005 | 04:27 AM
Default Re: (zeroice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zeroice &raquo;</TD></TR><TR><TD CLASS="quote">depends if you get the f22b dohc and its pretty much the same as the h23</TD></TR></TABLE>
right, unless he is talking about the DOHC, which I wouldnt have though of that since the norm when talking about F series is their lack of dual cam-ness. And I figured that he was talking about the H23 non-vtec. People have to be a little more specific sometimes. Would a better answer been 'one is a 2.2 and one is a 2.3'? You gotta calm down ZigenBalls, its not like I am spreading mis-information, I am totally right in what I am saying, the question just wasnt asked as it should have, if it would have been I would have given the same answer.. Theres 3 F22Bs (SOHC SOHC-VTEC and DOHC-VTEC) and 2 types of H23s (DOHC and DOHC VTEC.)
Old Jan 15, 2005 | 04:53 AM
zeroice's Avatar
Default Re: (di3go)
the dohc f22b is non vtec......last i checked
Old Jan 15, 2005 | 05:19 AM
'F22B - DOHC VTEC - Disp: 2156 '
'F22B - SOHC 16v - Disp: 2156'
see what I mean? people gotta ask more in depth questions yo.
Old Jan 15, 2005 | 09:26 AM
darwinizm's Avatar
Default Re: (di3go)
the JDM f22b is DOHC, non vtec
edit: everyone makes mistakes
Old Jan 15, 2005 | 09:38 AM
fast93accord's Avatar
Default Re: (mysterious_2)
The F22a, F22b, and H23 all use the same crankshaft, bearings, and rods. The only differnce is the F22a and b have an 85mm bore, while the H23 uses an 87mm bore. All the F series and H series bottom ends are almost identical. Personally i dont see what the big deal about dual cams is. Yeah, they free up a few hp compared to a single cam, but hey guess what, even with one of those motors in an accord your accord will still be slow, unless your using some sort of forced induction. Also with dual cams you are a lot more likely to have problems with cams going out of wack in the higher rpms, jumping t belts... As far as i'm concerned 1 cam is a lot less parts/metal then 2 cams. Unless you plan on making 1000hp, any single cam head cam be modified to perform the same as a twin cam head.
Depeche
Jun 12, 2007 10:37 PM
GraphiteMW
12
Mar 15, 2007 09:24 AM
crownsk8er
Dec 6, 2006 03:50 PM
farhan445
Nov 24, 2006 02:51 PM
shyboy_02
Sep 28, 2003 09:12 PM
