Need help to identify my engine
Old Jan 14, 2005 | 09:41 PM
nicehatchy's Avatar
Default Need help to identify my engine
I usually post in the eg section cause that is what i own but this is a different case. I recently baught a 93 cx with a swap. The engine is a D15B. At first i thought it was the jdm engine but it is non vtec and it is not very fast. The reason i posted here is because i had a friend with a 90 civic hatch and he had the same exact engine. It says D15B but it is non vtec. But i have not seen him in years. So maybe u guys can help me.
Was there any honda that was pre-92 with and engine code stamped d15b but was non vtec. thanks for the help
Old Jan 14, 2005 | 09:47 PM
PHOBIA's Avatar
yes, non of them were equpped with vtec.the non si models had the d sieres 1.5 liter motors, the si had a 1.6/_
Old Jan 14, 2005 | 09:52 PM
nicehatchy's Avatar
Default Re: (PHOBIA)
yeah but off of what civic did the "d15b" come out of . Because i know there is the "d15b7" and the "d15b2" but what civic has the "d15b" with no numbers after the b.
Old Jan 14, 2005 | 10:19 PM
31flavorscivic's Avatar
Default Re: (nicehatchy)
if it doesn't have numbers after it, then it's something JDM. That's a starting point; I don't know much past that.
mrspeaker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicehatchy &raquo;</TD></TR><TR><TD CLASS="quote">yeah but off of what civic did the "d15b" come out of . Because i know there is the "d15b7" and the "d15b2" but what civic has the "d15b" with no numbers after the b.</TD></TR></TABLE>
d15b is a jdm motor..and is sohc vtec..
Are you sure its not vtec.??
EDIT:: Actually I remember when I went back to barbados this summer my cousin there had a honda civic ferio-lev ..And it had "D15B" stamped on the engine and it was non vtec..The Hondas there are all J-spec...and it had a pcv-601 ecu and 2 4 wire o2 sensors....I've never heard of this **** so I was confused when I saw this..
Old Jan 14, 2005 | 10:32 PM
trustnoone7935's Avatar
Default Re: (Mrspeaker)
yea he's sure i have the same motor i have a crx and 93 hatch so i posted the same question in the eg forum and their is aparently a vtec version and a non-vtec version
Old Jan 15, 2005 | 05:40 AM
erebunicrx's Avatar
i did a search and came up with this. D15B 1493 130@6800 14.1kg/m@5200 9.6:1 75 84.5 sohc yes 1991-1999 Civic VTi (EG4).
for any engine codes you need check out http://www.hondaswap.com/forum...29825
Old Jan 15, 2005 | 06:27 AM
davens's Avatar
There was a D15b sold prior to 1992. It has no vtec and made 91 or 100 PS(90 or 99 Hp) depending on trim.
Here's a chart straight from the Honda archives. I realize you probably can't read japanese but if you go 3/4 of the way down the page, you'll see several engine codes and coresponding PS/rpm ratings.
http://www.honda.co.jp/factboo....html
There are even multiple versions of the D15b made from 92-95...not all of them had vtec and 130 PS. Two others made 100 and 94 PS.
Old Jan 15, 2005 | 08:56 AM
PHOBIA's Avatar
oh wait a sec.i had thatmotor in my auto 94 civic lx.now that i think about it.i had the same motor in my 88 dx hatch.onlly my 88 dx didnt have any numbers but was the stock motor.
E9CiViC1F
36
Jun 18, 2011 09:03 AM
Bambii_X
May 2, 2010 07:31 PM
jlicrx
Jun 27, 2003 07:52 AM
JinMTVT
Jun 14, 2003 07:59 AM
UhWhatsaVTEC
16
Jan 19, 2003 10:16 AM
