Need some help.... car is wabbling like crazy
Old Jan 14, 2005 | 08:38 PM
FOrSfEd's Avatar
Default Need some help.... car is wabbling like crazy
well I was out tonight taken a couple friends for a ride and i get on it had a good bit of torque steer and all of a sudden my car starts to wobble. It kinda felt like my tire was not on tight or maybe my lug nuts were loose but after checking them I know that is not the problem. So then i check the axel it seemed fine. The only other thing I can think if is a wheel bearing though i don't know what the symptoms of a bad wheel bearing is. CAn anyone help me out with this. any suggestions on what it could be.
Old Jan 14, 2005 | 09:00 PM
Chris F's Avatar
Default Re: Need some help.... car is wabbling like crazy (FOrSfEd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOrSfEd &raquo;</TD></TR><TR><TD CLASS="quote">well I was out tonight taken a couple friends for a ride and i get on it had a good bit of torque steer and all of a sudden my car starts to wobble. It kinda felt like my tire was not on tight or maybe my lug nuts were loose but after checking them I know that is not the problem. So then i check the axel it seemed fine. The only other thing I can think if is a wheel bearing though i don't know what the symptoms of a bad wheel bearing is. CAn anyone help me out with this. any suggestions on what it could be.
It COULD be that your tire is starting to separate and is no longer round. Hopefully that's all it is.
Maybe you can get some better suggestions. Good luck.
-Chris
Old Jan 14, 2005 | 09:52 PM
Bbasso's Avatar
Jack the car up and grap the tire/rim, does it shake? If so stop driving it and have it looked at asap.
Old Jan 15, 2005 | 05:51 AM
FOrSfEd's Avatar
Default Re: Need some help.... car is wabbling like crazy (Bbasso)
U mean once it is in the air grab it and try and shake it? If so i did that it seemed fine, though when i took the wheel off and put it back on and manually turned the wheel it seemed like it was not turning right, looked like it was off center.
Old Jan 15, 2005 | 07:02 AM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOrSfEd &raquo;</TD></TR><TR><TD CLASS="quote">U mean once it is in the air grab it and try and shake it? If so i did that it seemed fine, though when i took the wheel off and put it back on and manually turned the wheel it seemed like it was not turning right, looked like it was off center.</TD></TR></TABLE>
Whoa, was the wheel acting "not centered" on the hub, or was it just the tire not centered? Wheel bearings detonated?? Hmmm..
Old Jan 15, 2005 | 07:06 AM
Stunna BEN's Avatar
Don't call it a comeback
Default Re: Need some help.... car is wabbling like crazy (Chris F)
3 things
Car has been sitting? = Warped Axle (my hatch)
Vibration at High speed = Balance, weights, car not centered up on hub the right way, stupid people working on the car
Tire could have flatspots
Only other thing i could think is Ball joint issues, which could cause wabble, but not bumpiness
Old Jan 15, 2005 | 08:48 AM
FOrSfEd's Avatar
Default Re: Need some help.... car is wabbling like crazy (.Stunna.)
Thanks for all the replys fellas, I put it on a lift and drove the car and it seemed like the axel bent right at the knuckle which is what is making it wobble. hopefully I am right, so I'm going to fix that and see what happens. hopefully it did not bend inside the tranny though i doubt it since the the tranny is a hell of alot stronger than the end of the knucle. I'll post the verdit once i get it fixed.
Old Jan 15, 2005 | 08:50 AM
Stunna BEN's Avatar
axle
Stunna = teh WIN!
Old Jan 15, 2005 | 08:53 AM
FOrSfEd's Avatar
lol yeap, you got it.
Old Jan 15, 2005 | 09:01 AM
Stunna BEN's Avatar
Petruding lips only
Gently, extend your head and lean down to my ***
Please lips on left cheek
Old Jan 15, 2005 | 10:43 AM
mikestypeRR's Avatar
its your inner joint on your axle ... the same thing happened to me.
i made a thread about it and got it fixed. dont buy a whole new axle if you can just get the inner join assembly.
Old Jan 15, 2005 | 02:36 PM
Stunna BEN's Avatar
Default Re: Need some help.... car is wabbling like crazy (mikestypeRR)
MIKE!
Great info
Old Jan 15, 2005 | 04:37 PM
totsie7944's Avatar
i see you are pretty sure its the axle. but when i used to have my jeep, snow got in my springs and froze to solid ice and the car basically had no springs soo it shook like hell and wabbled at speeds over 35 mph. I had to hook a hose up to a sink that night and spray hot water on them to melt it.
They were fine after that lol
Old Feb 8, 2005 | 07:00 AM
FOrSfEd's Avatar
Default Re: Need some help.... car is wabbling like crazy (totsie7944)
Old Feb 8, 2005 | 08:22 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Stunna. &raquo;</TD></TR><TR><TD CLASS="quote">MIKE!
Great info</TD></TR></TABLE>
The first time this happened to my car all I did was replace the inner joint, it recently happened again this time i went ahead and replaced the whole axle.. so if it happens agian, then I know that there is another BAD part causing the axel to fail.
Byaaah!
Jun 18, 2007 07:25 PM
87shytwhip
Dec 8, 2006 12:09 PM
sExy_TinKY
Dec 26, 2005 11:11 PM
TypeRKoncepts
Oct 12, 2005 03:30 PM
Tuesdaynightfever
11
May 26, 2005 12:05 PM
