d-series motor setup
Old Jan 14, 2005 | 06:01 PM
DOHClessEF-9's Avatar
Default d-series motor setup
i just want your input if this would be a good combination for my dseries setup, im planning to use a d16a6 block with d16a1 pistions so it could boost up the compression, then make a mini me out of it with a z6 head probally with a cam, i/h/e so has this setup been made???? well if it has sorry for a re post so if anyone has seen one or at least give me an idea to what the motor could put out thanx in advanced
Old Jan 14, 2005 | 06:03 PM
altoid's Avatar
Default Re: d-series motor setup (pnoyra5er808)
ok you'll be running at least 13:1 comp. you got high octane?
Old Jan 14, 2005 | 06:13 PM
Default Re: d-series motor setup (altoid)
its gonna be that high????
Old Jan 14, 2005 | 07:33 PM
Mach69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by altoid &raquo;</TD></TR><TR><TD CLASS="quote">ok you'll be running at least 13:1 comp. you got high octane?</TD></TR></TABLE>
Are you sure about that? That is pretty high, there is a website which will give you the c/r of several diff. setups. I dont have it on my laptop, but I have it on my desktop at home, which I will go to tomorrow. If you do have a 13:1 c/r then it is the A1 pistons that would be doing that. If you put at Y8 head you will probably be in the 14s, ouch.
Old Jan 14, 2005 | 08:01 PM
Default Re: d-series motor setup (Mach69)
dam maybe i should think twice about this setup but anymore inputs oh and thanx to those who did
Old Jan 14, 2005 | 08:09 PM
trustnoone7935's Avatar
don't change pistons, why bump up your compression are you gonna run boost or stay n/a?
Default Re: d-series motor setup (trustnoone7935)
stay n/a also can i run it on 92????
Old Jan 14, 2005 | 10:28 PM
31flavorscivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pnoyra5er808 &raquo;</TD></TR><TR><TD CLASS="quote">stay n/a also can i run it on 92????</TD></TR></TABLE>
I wouldn't run anything less than 92. When are we gona get that 100 octane pump gas that they have over in Japan??? christ...
Old Jan 15, 2005 | 12:52 PM
Default Re: d-series motor setup (31flavorscivic)
i know we need the 100 octane pumps
NINE9DC4
Apr 12, 2008 05:08 PM
lunch_box_4_life
12
Aug 23, 2007 01:40 PM
allmtrdc4
Mar 6, 2006 01:54 PM
SlowCGP_EJ8
Nov 10, 2005 06:58 PM
jinteg730
Nov 23, 2004 04:29 PM
