Stage 1 or Stage 2
Old Jan 14, 2005 | 04:57 PM
jeff(s)'s Avatar
Default Stage 1 or Stage 2
i have a d16y8, aem sri or cai, dc 4-1 header, greddy evo2 catback, how much difference would there be to have a crower stage 1 cam or a stage 2 with springs/retainers? would it be worth it to get the stage 2? car has 58k, any info would help, thanks in advance
Old Jan 14, 2005 | 05:09 PM
sohcvtec1995's Avatar
Default Re: Stage 1 or Stage 2 (jeff(s))
well i would get a cam gear, that way yuo can dial in the correct amount of cam advancement, or retard. also you will need to slap that bad boy onto a dyno. Most cams will help in the top end dept.
Old Jan 14, 2005 | 05:31 PM
jeff(s)'s Avatar
Default Re: Stage 1 or Stage 2 (sohcvtec1995)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 &raquo;</TD></TR><TR><TD CLASS="quote">well i would get a cam gear, that way yuo can dial in the correct amount of cam advancement, or retard. also you will need to slap that bad boy onto a dyno. Most cams will help in the top end dept.</TD></TR></TABLE>
so your saying i should just get a stage 1 and cam gear? or stage 2 vavle springs/retainers and cam gear? and of course dyno time
Old Jan 14, 2005 | 11:01 PM
jeff(s)'s Avatar
anyone else???
Old Jan 15, 2005 | 07:23 AM
jlacoy82's Avatar
71.192.16.183
Considering they cost the same, if you can swallow the 250+ dollars for springs and retainers, the stage 2 would be much more beneficial.
Old Jan 15, 2005 | 08:24 AM
Luserkid's Avatar
Default Re: Stage 1 or Stage 2 (jlacoy82)
What do you want... if its daily driven go with Stage 1.
No matter what you get you need a cam gear and tuning ASAP. Tuning sooner if you go with Stage 2. The car will run but not to its full potentional and you will cry when you drive like that for a month or so then get on a dyno and find out how much youve been missing.
Old Jan 15, 2005 | 10:02 AM
jeff(s)'s Avatar
Default Re: Stage 1 or Stage 2 (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">What do you want... if its daily driven go with Stage 1.
No matter what you get you need a cam gear and tuning ASAP. Tuning sooner if you go with Stage 2. The car will run but not to its full potentional and you will cry when you drive like that for a month or so then get on a dyno and find out how much youve been missing. </TD></TR></TABLE>
so a stage 1 with a cam gear and tunning would be best for a daily driver? and i dont need spring/retainers just tune time?
Old Jan 15, 2005 | 12:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeff(s) &raquo;</TD></TR><TR><TD CLASS="quote">
that would be your best bet. Like stated above if you want to drop the money for the springs/retainers go for it. But you have to factor in the amount of money that you will be spending. So my recommedation would be stage one, cam gear and dyno time.
Old Jan 15, 2005 | 01:25 PM
Eyes Only's Avatar
get a cam gear
xkrazyxjbrkerx75
Nov 4, 2009 10:48 PM
chadalac1712
May 10, 2007 06:43 AM
blackek00
Mar 11, 2005 01:53 PM
93EX-T
Jul 24, 2003 05:30 AM
