Shifting
Old Jan 14, 2005 | 04:33 PM
D for D series's Avatar
Default Shifting
On my EJ7 sometimes it wont let me shift into 1st &2nd, and other times 5th and reverse, you know how when u have the clutch out and u try to shift and it wont let you, its like that, what could be the problem of this random gayness
Old Jan 14, 2005 | 04:34 PM
wushubrian's Avatar
Default Re: Shifting (ZeroSkate9119)
Hows the condition of your clutch and your transmission... take a look at them ... they might need some repair.
Old Jan 14, 2005 | 04:36 PM
Default Re: Shifting (wushubrian)
clutch is 1 month old and tranny is still good
Kyles ej1's Avatar
that happened to me its was the clutch, it wasnt engaging
Old Jan 14, 2005 | 04:41 PM
Default Re: Shifting (93blkej1)
any other sug.
Old Jan 14, 2005 | 05:48 PM
sharky8513's Avatar
check your clutch slave...it might be worn out
Old Jan 14, 2005 | 06:04 PM
snoochtodanooch's Avatar
Default Re: Shifting (sharky8513)
yea maybe try bleeding the clutch, then replace it if neccasary.
Old Jan 14, 2005 | 06:35 PM
DAguyLS's Avatar
i'd def bleed it first
Old Jan 14, 2005 | 07:10 PM
graveltravel's Avatar
it might be your syncros also. just my .02 cents
Old Jan 15, 2005 | 05:48 AM
k24a4kid's Avatar
I'm a Jackass
Default Re: (graveltravel)
yeah same thing with my car. idk what it is, im starting to to think it's my clutch or syncros. Sometimes it bugs the **** out of me when im driving. Im gettin my swap soon so i don't care any more. I'll let you know what it is if i ever find out
Old Jan 15, 2005 | 06:44 AM
ROOROWNS's Avatar
Default Re: (turbofienD 04)
Hey i was driving a 1991 hatch that did that too. You had to stand up on the clutch to start the car . The clutch would only engage if it was totally against the back wall. Check your linkage make sure nothings in the way if its only certain gear it should be an external tranny prob.
Sean
Old Jan 15, 2005 | 07:03 AM
chris_c's Avatar
Default Re: (EG_Black_Hatch)
if the clutch is in fact only one month old i would bleed the system and change the MTF. it is a good start.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93blkej1 &raquo;</TD></TR><TR><TD CLASS="quote">that happened to me its was the clutch, it wasnt engaging</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG_Black_Hatch &raquo;</TD></TR><TR><TD CLASS="quote">Hey i was driving a 1991 hatch that did that too. You had to stand up on the clutch to start the car . The clutch would only engage if it was totally against the back wall. Check your linkage make sure nothings in the way if its only certain gear it should be an external tranny prob.
Sean</TD></TR></TABLE>
i read this often here. the clutch is engaged when the pedal is up. When the clutch is engaged, the release bearing is moved away from the diaphragm spring's release fingers. As the spring pivots over the fulcrum ring, its outer rim forces the pressure plate tightly against the clutch disc. At this point the clutch disc is clamped between the flywheel and pressure plate.
when you push the clutch pedal down, you disengage the clutch. if you where having problems starting is sounds more like a clutch saftey switch problem than a clutch problem itself.
meece0927
Jul 2, 2013 08:15 AM
13DevilsCamry
Apr 8, 2005 07:53 AM
tianporn
Nov 5, 2004 12:18 PM
Grease Monkey
Jul 13, 2004 10:37 AM
MisterHYBRID
Sep 27, 2002 03:50 PM
