Please help 3 wires left for distributor on h22 swap...searched EVERYWHERE
Old Jan 14, 2005 | 02:20 PM
azzinine1's Avatar
Default Please help 3 wires left for distributor on h22 swap...searched EVERYWHERE
96 LX Accord with a 93 JDM H22 three wires left to finish they are all for the distributor...
There is a green wire that went to the external coil where does it go now. There was a green wire that went to the accord distributor, where does it go now. And there is a yellow wire that ran to to distributor in the same clip as the blue wire for the tach...Someone please i have been searching for this for days. thanks
Old Jan 14, 2005 | 03:19 PM
precord96's Avatar
Default Re: Please help 3 wires left for distributor on h22 swap...searched EVERYWHERE (azzinine1)
You dont need the green wire anymore. That's the ignition signal from the old distributor to the external coil, not needed anymore because it's all built into the new H22A dizzy.
The Yellow and Black w/ yellow stripe should be cut and connected to each other. It's power, if you undo the harness wire loom, you'll know what I'm talking about.
Just do that and you should be fine.
Old Jan 14, 2005 | 03:28 PM
azzinine1's Avatar
Default Re: Please help 3 wires left for distributor on h22 swap...searched EVERYWHERE (precord96)
kool thanks..one more wire... a green wire that ran to the dizzy in a clip with four wires its a different one than the one that went to the external coil, the accord dizzy had a green wire that connected to it but the h22 doesnt have the green wire is it obsolete also??? and since the black/yellow and yellow splice together and dont go anywhere what powers the coil...is it the yellow wire thats in the clip with the blue wire that would connect to the dizzys black/yellow wire (the blue one is for the tachometer) THANKS FOR THE HELP EVERYONE...
Old Jan 14, 2005 | 03:42 PM
precord96's Avatar
the green wire is obsolete for an internal coil dizzy.
the yellow and black w/ yellow will end up powering the dizzy.
Old Jan 14, 2005 | 04:04 PM
azzinine1's Avatar
so once you splice the back/yellow with the yellow do you then run them to the black/yellow on the dizzy...some people told me you leave them alone but i dont understand how the coil would get power then...please help thanks
Old Jan 14, 2005 | 04:08 PM
precord96's Avatar
obviously you havent undone the harness to know what Im talking about. All the wires run from the dizzy to the external coil. so you connect the yellow and black/yellow and leave it. They run back to the dizzy on their own, you dont have to touch it beyond that. I told you that it is an easy mod, dont think too much into it. if you undo the harness wire loom and trace the wires then you will understand that they run back to the dizzy. You can either take my word for it or just undo the harness yourself to see it for yourself.
Old Jan 14, 2005 | 04:18 PM
azzinine1's Avatar
ill take your word for it...makes sense when i think about it
Old Jan 14, 2005 | 04:22 PM
azzinine1's Avatar
so now i know that i wire the black/yellow with the yellow and leave them alone, the green wire from the external clip does nothing that leaves me still with that other green wire unless im an idiot and im missing something...
Old Jan 14, 2005 | 04:57 PM
azzinine1's Avatar
thanks to Precord96 i now know that both green wires are useless...i tried to start it with the black/yellow and yellow wired to the dizzys black/yellow though...could this have fried the dizzy???
nicks00si
Oct 12, 2011 09:00 AM
MikeLuder
Aug 13, 2009 02:42 PM
azzinine1
Jan 14, 2005 03:13 PM
azzinine1
Jan 14, 2005 02:19 PM
H23vtecEG
Oct 14, 2003 05:02 PM
