Inquiry for those who bought the 4300K Philips kit from Visualdynamics
Old Jan 14, 2005 | 01:32 PM
TypeRod's Avatar
Default Inquiry for those who bought the 4300K Philips kit from Visualdynamics
Am I the only one who is having continuous problems with their kit? My low beams started acting funny after probably a year and a half after I got them. I've rewired them a few times but after a while they start acting up. I'm sure my wiring is good. Just wanted to know if I was the only one. Ohh, and does anyone know where I can get the connector that plugs into the ballast (the connector I'm referring to is on the opposite end of the 9006 adapter. TIA!
Old Jan 14, 2005 | 01:53 PM
jdmvtec28's Avatar
Default Re: Inquiry for those who bought the 4300K Philips kit from Visualdynamics (TypeRod)
Would you be so kinda as to clarify what "actin up" means?
IMHO I think all aftermarket kits have a tendency to be unreliable. Either the relays have problems, or if you have a poorly rebased bulbs they go bad... just a headache in general. Believe me it is well worth it, but definately a PIDA.
Old Jan 14, 2005 | 02:48 PM
TypeRod's Avatar
Default Re: Inquiry for those who bought the 4300K Philips kit from Visualdynamics (jdmvtec28)
One of the lights wouldn't turn on sometimes. Or it would go out while I'm driving.
PureTeg420's Avatar
4 years and no problems here.
Old Jan 14, 2005 | 04:00 PM
Alexander's Avatar
Default Re: Inquiry for those who bought the 4300K Philips kit from Visualdynamics (PureTeg420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PureTeg420 &raquo;</TD></TR><TR><TD CLASS="quote">4 years and no problems here. </TD></TR></TABLE>
Old Jan 14, 2005 | 04:06 PM
Mugen Mike's Avatar
2.5 years and no problems here.
Maybe check the ground wires from the ballasts?
white rocket's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeRod &raquo;</TD></TR><TR><TD CLASS="quote">One of the lights wouldn't turn on sometimes.</TD></TR></TABLE>
I don't have the same kit but that happened to me a few weeks after I had them put on. The problem seems to have fixed itself. Weird.
Old Jan 14, 2005 | 04:12 PM
RTW DC2R's Avatar
seems to be a similar issue here https://honda-tech.com/zerothread?id=613012
Old Jan 14, 2005 | 04:21 PM
TypeRod's Avatar
Default Re: (RTW DC2)
I guess I'm just gonna re-wire AGAIN! hehe! I found that connector I was looking for. I'm gonna change that out because I just soldered the 9006 adapter last week. It seems to only happen to the low beams, my HID 9005's (also bought from Trevor) havent gone bad at all, and I use them all the time.
Old Jan 14, 2005 | 04:25 PM
TypeRod's Avatar
Default Re: Inquiry for those who bought the 4300K Philips kit from Visualdynamics (Mugen Mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Mike &raquo;</TD></TR><TR><TD CLASS="quote">2.5 years and no problems here.
Maybe check the ground wires from the ballasts?</TD></TR></TABLE>
Hey Mike, what "ground wires from the ballast" ?
Old Jan 14, 2005 | 04:45 PM
Mugen Mike's Avatar
There should be 2 ground wires (one for each ballast). If the do not a a good connection, it will cause problems.
Old Jan 14, 2005 | 04:57 PM
TypeRod's Avatar
This kit uses the stock 9006 connector which a 9006 adapter is plugged into that. Then that harness leads to the ballast, then from the ballast is just on really thick wire which the D2S bulb is attached. There arent any extra ground wires on the ballast, I guess everything is grounded through the stock headlight harness.
Old Jan 14, 2005 | 05:09 PM
Jim80y's Avatar
I've had this issue before, all it was was the harness; one of the soldered connections had come loose from the plug.
Old Jan 14, 2005 | 05:14 PM
Mugen Mike's Avatar
I dunno, I haven't look at the wireing for some time, but I am positive that there are 2 ground wires, just as there are 2 positive wires that connect to the battery...maybe they are part of the wiring harness.
I had a problem with one of the grounds after I got the front end of my car repaired at a body shop. Fixed the ground and everythng is fine again.
zerg1024
Lighting
Sep 24, 2008 10:03 AM
hometheaterman
May 11, 2006 01:11 AM
tegrunner
Jun 17, 2005 11:17 PM
Knightmare69
Nov 17, 2004 10:17 PM
Squirtin EGsr
Feb 13, 2004 08:40 AM
