gt32+d16z6 good match or what??
Old Jan 14, 2005 | 12:42 PM
rextec's Avatar
Default gt32+d16z6 good match or what??
im looking to get about 300-350whp at 16ish psi on pump gas with a decent powerband with plenty of midrange. i was going to use an sc34 with a .63 but it seems like it would take forever to spool so im selling it. judging by this comp map would it be a good choice for my d16 and goals? what will the spool characteristics be like on this motor? any input will be appreciated!
btw: does this turbo calc. do the math correctly? http://www.mrapg.net/hondatech/turbocalc-v1.xls right click save as
Modified by rextec at 9:54 PM 1/14/2005
Old Jan 14, 2005 | 08:38 PM
rextec's Avatar
dont all you chime in at once!
Old Jan 14, 2005 | 10:41 PM
z6's Avatar
z6
perfect match
Old Jan 15, 2005 | 12:18 AM
peiku's Avatar
Default Re: (z6)
i would also like to know. i want those numbers too. free bump!
Old Jan 15, 2005 | 01:07 AM
quik sol's Avatar
300-350whp is alot for a D series engine, do you have any internal mods to this or no?
Old Jan 16, 2005 | 10:12 AM
rextec's Avatar
stock sleeves, eagle rods, cp pistons...
Old Jan 16, 2005 | 10:49 AM
2point2's Avatar
I made that spreadsheet!!.. i wouldn't trust it very much
Old Jan 16, 2005 | 12:19 PM
DaZman69's Avatar
Default Re: (2point2)
sc34 is very big...what about sc32? for those power goals I say disco potato
Old Jan 16, 2005 | 02:47 PM
Boltz's Avatar
Default Re: (DaZman69)
I dont think you should set goals for say 300-350whp @ a certain PSI. It will take quite the turbo to make 350whp on a D series @ 16psi.
Instead find the turbo that is capable of what you want to accomplish and see how much boost you need to achieve your power goals while tuning.
I have a turbo that I consider too big on my D series (SC32, .63) and only made about 255whp @ 1 bar. But at 1.2 bar I made about 290whp (obviously the turbo is more efficient at the higher boost levels.
Smaller turbo and more boost is the way to go. Id say a .48 50 trim would be badass and inexpensive.
Old Jan 16, 2005 | 02:52 PM
DaZman69's Avatar
Default Re: (Boltz)
disco potato would be perfect
Old Jan 16, 2005 | 03:57 PM
rextec's Avatar
i looked at the disco potato but its out of my price range. the gt30 is capable of more power (room to grow) and is cheaper because it not bb, but it still retains the gt technology.
Old Jan 17, 2005 | 08:32 AM
RyanEJ8's Avatar
Default Re: (quik sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik sol &raquo;</TD></TR><TR><TD CLASS="quote">300-350whp is alot for a D series engine, do you have any internal mods to this or no?</TD></TR></TABLE>
Really that's not alot for a D series.
Old Jan 17, 2005 | 10:15 AM
rextec's Avatar
ttt
Old Jan 17, 2005 | 01:19 PM
rextec's Avatar
can someone who know how to plot on the turbo map let me know how this matches up?
Old Jan 18, 2005 | 10:33 AM
rextec's Avatar
anyone else out there?
Old Jan 18, 2005 | 11:42 AM
z6's Avatar
z6
to plot out your map, i need to know your plan, which displacement you will be using and how high you plan on revving. from there i can establish an approximate air flow number (in lbs of air)
so fill in the blanks and ill hit u back
Old Jan 18, 2005 | 01:26 PM
rextec's Avatar
the displacement is 1611cc comp ratio. 9.2:1, i plan on reving to 7200 (unless i get the head built then ill go 8000). thanks man
Old Jan 18, 2005 | 02:47 PM
z6's Avatar
z6
Default Re: (rextec)
this graph assumes the following
98cubic inch (1.611L)
7200rpm
85% top end effiency (stock intake/head)
boost at 7psi/15psi/22psi
heres the link if the pic dont work
http://www.imagestation.com/pi...2.jpg
Old Jan 18, 2005 | 07:24 PM
rextec's Avatar
wow that is beautiful! that is a perfect match for me. thank you very much!
Old Jan 18, 2005 | 07:51 PM
z6's Avatar
z6
yea no problem man, just save that graph if u need it cuz ill prolly host sumthing else soon and it might dissapear
if you have any more u need, let me know, it'd be a pleasure
Old Jan 20, 2005 | 12:51 PM
Zer0DazE's Avatar
how is that a "perfect" match.. its barely in the center island.
i think its an ok match, but not perfect by any means
Old Jan 20, 2005 | 12:56 PM
Boltz's Avatar
Default Re: (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">
Really that's not alot for a D series.</TD></TR></TABLE>
I think it is, How many people do you actually see running more than 300whp in a street setup? (Dont list boosted ED9, because he was at full timing advance and only using an AFC)
I've done what I consider a ****-load of work on my car and it feels like I should have gone B series. Hell there are stock LS's making more than me (I made 286whp @ 17.5 psi on an SC32) But my tuner feels that even at that level I am pushing it.
Just looking for some good discussion
Old Jan 20, 2005 | 07:56 PM
rextec's Avatar
Default Re: (Zer0DazE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zer0DazE &raquo;</TD></TR><TR><TD CLASS="quote">how is that a "perfect" match.. its barely in the center island.
i think its an ok match, but not perfect by any means</TD></TR></TABLE>
it looks like its right in the middle island to me.
Old Jan 21, 2005 | 11:40 AM
rextec's Avatar
bump!!
Old Jan 21, 2005 | 12:57 PM
Zer0DazE's Avatar
at 15 psi, at redline
dont you think it would be nice to may be have it spool a little faster... and maybe have the turbo in that center island a little longer, and fall out of it as your shifting?
bah, that would be silly
get a bigger turbo...
